Work and energy (Using calculus to solve)
The discussion revolves around solving work and energy problems using calculus, specifically focusing on three scenarios involving a hanging cable, a climbing monkey, and gravitational force at different altitudes. The scope includes mathematical reasoning and problem-solving techniques.
  • Homework-related
  • gigi9 requests assistance with three specific problems related to work and energy, asking for guidance on the formulas and integrals to use.
  • In response to the first problem, a participant suggests a method involving definite integrals and provides a calculation that results in 120000J, though the reasoning behind the calculation is questioned by others.
  • Another participant challenges the formula used in the third problem, questioning whether the correct gravitational force equation is being applied, suggesting that constants cannot be integrated directly.
  • For the second problem, a participant proposes a formula for the force experienced by the monkey as it climbs, incorporating both the monkey's weight and the weight of the chain, leading to a calculated work of 195 ft-lbs.
  • PrudensOptimus critiques the clarity of the first participant's solution and offers an alternative approach to calculating work based on the weight of the cable remaining as it is wound up.
Participants express differing views on the methods and formulas to be used for the problems, with no consensus reached on the best approach or the correctness of the calculations presented.
Some participants express uncertainty about the units of energy in the imperial system, and there are unresolved questions regarding the integration of constants in gravitational equations.
gigi9
Someone please help me to do these problems below...show me what foruma/ integral to use... Thank you very much.
1) A cable 600 ft long that weighs 4 lb/ft is hanging from a windlass. How much work is done in winding it up?
2) A 5-lbs monkey is attached to the end of a 30-ft hanging chain that weighs 0.2 lb/ft. It climbs the chain to the top. How much work does it do?
3) If R is the radius of the earth(about 4000 mi) and g is the acceleration due to gravity at the surface of the earth, then the force of attraction exerted by the Earth on a body of mass m is F=mgR^2/r^2, where r is the distance from m to the center of the earth. If this body weighs 100lb at the surface of the earth, what does it weigh at an altitude of 1000mi? How much work is required to lift it fromt eh surface to an altitude of 1000 mi?
#1: ΣW = ∫F dx = m∫a dx = m∫dv/dt * v*dt = m∫v dv. Since it's a definite integral from 0 to 600, it = 4[(600)^2/2] - 0.
&Simga;W = 120000J.
#3: You sure it's F = mgR^2/r^2? Not the universal gravitation equation? m,g,R,r are all constants... and none of them can be integrated
Unless you use I = ∫r^2 dm...
I'm going to take a swing at this one. I will put the force as this:
F = 5 + (0.2)x/2
I'm thinking this is the formula because the weight of the monkey is a constant 5 and the length of the chain is only half of the height he climbs. If he climbs up the full 30ft , only 15ft of chain will hang from him.
F = 5 + 0.1x
E = ç5 + 0.1x dx
E = 5x + 0.1x^2/2
E = 5x + 0.05x^2
E = 5(30) + 0.05(30)^2
E = 195ft-lbs
I don't know the imperial system so I don't know what your unit for energy is.
Huh? Yes, you got the "right answer" but who knows how. :smile:
Try this:
W = ∫F ds , where ds is the displacement.
The force at any point is the weight of the cable that's left hanging. Call the hanging length "x". (xi= 600; xf= 0) Thus:
F = λ x , where λ is the weight per unit length.
How does ds relate to dx? As ds goes up, dx goes down (the hanging length gets shorter): so, ds = -dx. Thus,
W = ∫F ds = - λ∫x dx (from xi to xf) = λ∫x dx (from xf to xi) = λxi2/2
Note to gigi9: Give the problems a try before asking for help! Then the help would make more sense. (Also, maybe you'll get more help in the Homework Help section.)
  • · Replies 24 ·
  • · Replies 41 ·
