Need help - projectile motion with air resistance
The discussion centers on analyzing projectile motion with air resistance, specifically comparing the time to reach maximum height under two conditions: without air resistance and with a resisting force proportional to velocity. The user correctly identifies the equation of motion for the projectile with air resistance as F = m dv/dt = kv - mg, leading to the differential equation dv/dt = kv - g. The initial condition for solving this equation is established as v(t=0) = v0, where v0 is the initial velocity.
  • Understanding of Newton's second law of motion
  • Familiarity with differential equations
  • Knowledge of projectile motion principles
  • Concept of air resistance modeled as a force proportional to velocity
  • Study the derivation of the equations of motion for projectiles with air resistance
  • Learn about solving first-order linear differential equations
  • Explore the effects of varying coefficients of air resistance on projectile motion
  • Investigate numerical methods for simulating projectile motion with air resistance
Physics students, educators, and engineers interested in the dynamics of projectile motion and the effects of air resistance on trajectories.
don_anon25
Need urgent help -- projectile motion with air resistance
Consider a projectile fired vertically in a constant gravitational field. For the same inital velocities, compare the times required for the projectile to reach its maximum height (a) for zero resisting force and (b) for a resisting force proportional to the instantaneous velocity of the projectile.
For a, I get t=-v0/a.
For b, I have the equation F= m dv/dt=kmv-mg, which leads me to
dv/dt=kv-g.
Is this correct...If so, I can take it from here.
If not what should it be?? What should my initial condition be to solve for the constant? Should it be v(t=0)=v0?
Thanks much!
The resisting force is simply kv, rather than mkv and it is acting in the same direction as the gravitational force, mg.
Initial/end conditions are vi = vo and vf = 0.
  • · Replies 37 ·
