Football Projectile Calculations
  • Thread starter Thread starter courtrigrad
    Projectile
The discussion revolves around projectile motion, specifically analyzing the trajectory of a football thrown with given initial velocity components. Participants explore calculations related to time to reach maximum height, maximum height itself, time to return to the original level, and horizontal distance traveled.
  • Participants discuss the use of kinematic equations to determine time to reach maximum height and maximum height itself. There are questions about the equality of times for different parts of the problem and how to calculate horizontal distance traveled. Some participants suggest methods involving derivatives and setting equations to zero.
Some participants have provided calculations and expressed confidence in their results, while others have raised questions about the correctness of specific steps and assumptions. There appears to be a mix of agreement and differing interpretations regarding the calculations.
Participants are working under the assumption of neglecting air resistance and are exploring the implications of this assumption on their calculations.
courtrigrad
A football player throws a football with an initial upward velocity component of 18.0 m/s and a horizontal velocity component of 25.0 m/s. (a) How much time is required for the football to reach the highest point of the trajectory? (b) How high is this point? (c) How much time (after being thrown) is required for the football to return to its original level? How does this compare with the time calculated in part (a)? (d) How far as it traveled horizontally during this time?
(a) Ok so I know that [itex]v_{x}_{0} = 25.0 m/s, v_{y}_{0} = 18.0 m/s[/itex]. So for part (a) we know that the vertical component of velocity [itex]v_{y} = 0[/itex]. So would I use [itex]t = \frac{v_{0}\sin\theta_{0} - v_{y}}{g}[/itex] where [itex]v_{y}_{0} = v_{0} = 18.0 m/s, v_{y} = 0, \theta = 90, g = 9.8 m/s^{2}[/itex]?
(b) Would I use [itex]y = (v_{0}\sin\theta_{0})t - \frac{1}{2}gt^{2}[/itex] and plug in the time?
(c) wouldn't the times for part(a) and part (c) be equal neglecting air resistance?
(d) I would just find the time for the football to travel the horizontal distance and use the equation [itex]R = (v_{0}\cos\theta_{0})t_{2}[/itex]?
Thanks
(a) Ok so I know that [itex]v_{x}_{0} = 25.0 m/s, v_{y}_{0} = 18.0 m/s[/itex]. So for part (a) we know that the vertical component of velocity [itex]v_{y} = 0[/itex]. So would I use [itex]t = \frac{v_{0}\sin\theta_{0} - v_{y}}{g}[/itex] where [itex]v_{y}_{0} = v_{0} = 18.0 m/s, v_{y} = 0, \theta = 0, g = 9.8 m/s^{2}[/itex]?
Thanks
Remember that v=<25.0, 18.0>m/s. You can either plug that in and find your vertex (similar to what you suggested above) or differentiate and set equal to zero (if you don't know how to take a derivative yet, forget I said that). To find the time it takes for it to hit the ground, you set the y equation equal to zero (do you see why?) You will have two roots to this equation, one being your initial time and the other being the time you need to find. I hope this helps.
Alex
yeah I think I got it. Is this correct:
(a) [itex]t = \frac{v_{0}\sin\theta_{0} - v_{y}}{g} = \frac{18.0 m/s}{9.8 m/s^{2}}, t = 1.1836 s[/itex]
(b) [itex]y_{max} = (18 m/s)(1.86) - \frac{1}{2}(9.8 m/s^{2})(1.836)^{2} = 16.53 m[/itex]
(c) [itex]t_{2} = \frac{2v_{0}\sin\theta_{0}}{g} = \frac{ 36 m/s}{9.8 m/s^{2}} = 3.673 s[/itex].
(d) [itex]R = (v_{0}\cos\theta_{0})t_{2} = (25 m/s)(3.673 s) = 91.83 m[/itex]
Thanks
is this correct?
You upward velocity is 18 m/s, decresaing by 9.8 m/s², so time to reach zero velocity, at which the foorbal is at its maximum height is,
t = Vy/g
t = 18/9.8
t = 1.837 s
(b) is correct
(c) is correct
(d) is correct
