Question 1st law of Thermodynamics
The discussion focuses on a thermodynamics problem involving a piston-cylinder device containing steam. Initially, the device holds 0.01 m³ of steam at 200°C and 500 kPa. Steam at 1 MPa and 350°C enters the cylinder, doubling the volume to 0.02 m³. The participants analyze the final temperature and mass of steam in the cylinder using the first law of thermodynamics, with calculations involving specific volumes and enthalpies from superheated steam tables.
  • Understanding of the first law of thermodynamics
  • Knowledge of steam tables for superheated water vapor
  • Familiarity with piston-cylinder device operations
  • Ability to perform calculations involving specific volume and enthalpy
  • Study the first law of thermodynamics in detail
  • Learn how to use steam tables for superheated steam
  • Explore the behavior of gases in piston-cylinder systems
  • Practice solving similar thermodynamic problems involving phase changes
Students and professionals in mechanical engineering, particularly those specializing in thermodynamics, as well as anyone involved in steam system design and analysis.
kuwait
Hi
I have a question please can you give me a hint how to solve it. It is in thermodynamics
A vertical piston-cylinder device initially contains 0.01 m^3 of steam at 200 C. The mass of the frictionless piston is such that it maintains a constant pressure of 500 kPa inside. Now steam at 1 MPa and 350 C is allowed to enter the cylinder from a supply line until the volume inside doubles. Neglecting any heat transfer that may have taken place during the process, determine (a)the final temperature of the steam in the cylinder and (b)the amount of mass that has entered.
This is were my solution but i couldn't complete it:
State(1):500 kPa, 200 C, 0.01 m^3
State(2):500 kPa, 0.02 m^3
at the inlet: Pi=1 MPa, Ti=350 C
I've found that state 1 and the steam entered are super-heated and i got specific volume for the inlet and state 1 also the h and u from the table of super-heated water vapor
then got m1=V1/v1
m(inlet) = m2-m1
-W + (m h)inlet = m2 u2 - m1 u1...(1)
m of the inlet, m2 and u2 are unknowns
W=P(V2 - V1) = 500(0.02 - 0.01) = 5kJ
or we can write eq(1) as:
m2 h2 - m1 h1 - (m h)inlet = 0
m2, h2 and m of the inlet are unknowns
since h = Pv + u
please can you help me?
My naive approach is:
- since the additional gas has double pressure, it has double density. Thus, the final mass is 3 times the initial mass.
- since temperature is energy per particle, the resulting temperature is (T1 + 2 T2)/2, where everything is in Kelvins.
thank you
i knew how to solve
