Air flow speed at top of airplane wing
The discussion centers on calculating the airflow speed over the top surface of an aircraft wing required to achieve a lift of 25.4 lb/ft², given a bottom surface airflow speed of 500 ft/s. The user employs the equation Pb - Pt = 1/2p(Vf² - Vb²) and attempts to solve for Vf, but encounters unit conversion issues. The correct approach involves recognizing that 25.4 lb/ft² corresponds to a pressure difference and ensuring consistent unit usage throughout the calculations. The final result should yield a top surface speed of approximately 519 ft/s when properly calculated.
  • Understanding of fluid dynamics principles, specifically Bernoulli's equation.
  • Familiarity with unit conversions between pounds, slugs, and feet.
  • Knowledge of lift generation in aerodynamics.
  • Basic algebra skills for solving equations.
  • Study Bernoulli's equation in detail to understand pressure differences in fluid flow.
  • Learn about unit conversions in fluid dynamics, focusing on pounds, slugs, and pressure units.
  • Research the principles of lift generation and airflow over wings in aerodynamics.
  • Practice solving similar problems involving airflow and lift calculations using different parameters.
Aerospace engineers, physics students, and anyone involved in aerodynamics or fluid mechanics who seeks to understand airflow dynamics around aircraft wings.
kashmirekat
Hello all,
Here's my problem, verbatim:
An aircraft wing requires a lift of 25.4 lb/ft^2. If the speed of flow of the air along the bottom surface of the wing is to be 500ft/s, what must be the speed of flow over the top surface of the wing to give the required lift?
(NOTE: Density of air is 2.54 x 10^-3 slug/ft^3)
F = 25.4lb/ft^2 = 0.789 slug/ft^2
Vb = 500ft/s
The equation I am using is
FA = 1/2p(Vf^2-Vb^2)A
However, I do not have the area for this problem and I was told that I don't need it, to use the equation Pb - Pt = 1/2p(Vf^2-Vb^2) and the 25.4 lb/ft^2 corresponds to (Pb-Pt). I've tried doing the equation, but units do not come out correctly.
0.789 slug/ft^2 = 1/2(2.54 x 10^-3 slug/ft^3)(Vf^2 - (500ft/s)^2)
0.789 slug/ft^2 = (1.27 x 10 ^-3 slug/ft^3)(Vf^2 - 250,000ft^2/s^2)
0.789 slug/ft^2 = (1.27 x 10 ^-3 slug/ft^3)Vf^2 - 317.5 slug/fts^2
0.789 slug/ft^2 + 317.5 slug/fts^2 = (1.27 x 10 ^-3 slug/ft^3)Vf^2
621.26ft + 250,000ft^2/s^2 = Vf^2
Where did I go wrong? Some people were getting 519, but that's only if you use 25.4 lb/ft^2, and you can't do that unless you ignore units of lb and slug.
Thank you for your help and have a nice day!
lb/ft^2 does not convert into slugs/ft^2
It coverts into [tex]\frac{slug*\frac{ft}{sec^2}}{ft^2}[/tex]
or
[tex]\frac{slug}{ft*sec^2}[/tex]
Thank you.
