Thread Closed
Calculating total resistance
Share Thread Thread Tools
Oct6-05, 03:47 PM   #1
This is going to sound like such a stupid question, but I'm a bit of a pickle:
Below is a circuit
I'm being asked to work out
[a] total resistance
[b] the cell current
[c] the p.d, current and power delivered to each resistor
[d] the electrical power delivered by the cell
right, when starting [a] would my question be something like:
1/4 + 1/12 + 3 = R[total]
I'm just a *bit* stuck
Thanks for the help anyway! (I know it's probably the most stupid question in the world)
John
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Oct6-05, 03:52 PM   #2
Recognitions:
Homework Helper Homework Help
No, look at the units in that equation. First find the equivalent resistance for the two parellel resistors, then add this to the third.
Oct6-05, 03:55 PM   #3
I'm seriously too lost to work that out :(
Oct6-05, 03:58 PM   #4
Don't forget the equations for this:
Resistors in series: R(T) = R1 + R2 + R3 and so on...
Resistors in parallel: 1/R(T) = 1/R1 +1/R2 + 1/R3 and so on...
where R(T) is the total resistance.
But you must work out the series and parallel bits separately. First, forget about the final resistor and consider the two that are in parallel. Then work out the total for the whole circuit.
Hope this is clear and it helps!
Oct6-05, 04:02 PM   #5
I seriously don't know how to do it though
adding the two parallel ones together
like:
1/4 + 1/12
= 3/12 + 1/12
= 1/3
I guess that isn't the right thing to do?
Oct6-05, 04:06 PM   #6
No your right so far...
what you have calculated so far is 1/R(T) which you have found to be 1/3. So, you need R(T). Can you work it out from here?
Oct6-05, 04:07 PM   #7
it would be 3 + 1/3 ?
So it would be 3.33333333... ?
Oct6-05, 04:23 PM   #8
no no...
You still haven't worked out the actual resistance for the parallel part yet. You worked out that 1/R(T) = 1/3
Now, to get from 1/R(T) to R(T) you turn over the fraction right? Well, you know that doing one thing to one side of an equation means you have to do it to the other side, so by the same principle...
1/3 becomes ...?
Once you get this, you can redraw your circuit diagram, and replace the two parallel resistors with a single one with resistance equal to the answer to "1/3 becomes ...?".
This means that the calculation becomes a simple one with just two resistors in series, which is simple to calculate.
Hope this helps!
Oct6-05, 04:58 PM   #9
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
bacnka, I know that you said that you are too lost to heed the suggestions by StatusX and comwiz72, but you are going to have to get un-lost in a hurry if you expect to pass this course. The point they are making is so basic that you will not make it without "getting it".
Quote by bacnka
First of all: Think, don't guess.
These numbers have units on them. You aren't just adding 3 to 1/3, you are adding 3 OHMS to 1/3 INVERSE OHMS. You cannot add two quantities that have different units.
Thread Closed
Thread Tools
Similar Threads for: Calculating total resistance
Thread Forum Replies
Multiloop Circuit Total Resistance Introductory Physics Homework 5
total resistance Introductory Physics Homework 4
Total resistance and fractions. Engineering, Comp Sci, & Technology Homework 2
Total resistance in parallel circuits Introductory Physics Homework 3
Total Resistance Introductory Physics Homework 6
