Program that calculates distances of a rocket
  • Thread starter Thread starter Tom McCurdy
    Program Rocket
The discussion revolves around calculating new GPS coordinates for a rocket's trajectory based on an initial position and specified distances traveled north and east. The subject area includes concepts of geography and coordinate systems.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore how to convert distances traveled into changes in latitude and longitude. There are questions about the accuracy of the conversion factors used, particularly the relationship between seconds of arc and meters.
Some participants have provided calculations and methods for determining the new coordinates, while others raise concerns about the precision of the results and the order of movements affecting the outcome. There is an ongoing exploration of the implications of these calculations.
Participants note the requirement to submit coordinates in latitude/longitude format and discuss the significance of significant digits in the results. There is also mention of the Earth's radius affecting the calculations.
Tom McCurdy
Urgent Help Needed!
Alright I have an odd question
I have this point at
42.29179 degrees N, 83.71636 degrees W
and I have this program that calculates distances of a rocket I'm firing that goes like 50 meters north and 100 meters east and i need to calculate the new GPS coordinates...
How Would i do this... I need to submit my new coordinates in less than 4 hours!
thx
tom
s
I have read somewhere that a second is about 30.9 meters, but I'm not sure about this yet.
I need a more accurate translation of how many meters are in a second
The length of 1 second of arc in longitude depends on the latitude.
So what would be the new coordinates from
That is 50 Meters North and 100 Meters more east
and how would i do the calculations for that
To get the coordinates of the system first the simulation was run. The simulation shows most of the coordinates landing about 100 meters East and 50 meters North of the starting position. To calculate the new coordinate from this I researched and found that one second is approximetly equal to 30.9 meters. Then I took 100/30.9=3.236 seconds added East. To get the fractional part that 3.236 seconds add I simply take 3.236/(60*60)=0.000899 degrees. A similar method is employed in finding the added north componet. 50/30.9=1.618 seconds 1.618/(60*60)=0.000449
This gives 42.29179 degrees N + 0.000899 degrees N=42.29269
83.71636 degrees W- 0.000449 E (subtract since its in the east direction) =83.71591
You have a little bit of a problem here though, practically speaking, it is unlikely to make much real difference but you are displaying 7 significant digits. The coordinates you end up with will be slightly different depending on whether you go 50 m north then 100 m east or 100 m east then 50 m north!
I'll let you work out the details but suppose the radius of the Earth is R (for simplicity take it to be in meters). Then, in traveling north or south, the change in latitude is
[tex]\Delta latitude = \frac {distance}{R}[/tex]
In traveling east or west the change in longitude is
[tex]\Delta longitude = \frac {distance}{R \cos latitude}[/tex]
with signs appropriate to the direction of travel. Notice that the change in longitude depends on the latitude at which you begin your east-west travel.
(Unfortunately TeX isn't working so I'm not sure how those equations look.)
had to delte
Unfortuently I'm required to give the coordinates in lat/long form.
If you know the coordinates in lat/long form and you calculate the changes in lat/long then you can simply write the new coordinates in lat/long form. I don't see the problem.
  • · Replies 16 ·
