Is this the simplesft form? i put it in a k-map
  • Thread starter Thread starter mr_coffee
    Form
The discussion revolves around the simplification of a Boolean expression using a Karnaugh map (K-map). Participants evaluate whether the provided expression is in its simplest form, focusing on the methodology of grouping in the K-map.
  • Technical explanation, Debate/contested, Homework-related
  • One participant shares their work and asks if their K-map representation is the simplest form.
  • Another participant argues that the expression is not in its simplest form, suggesting that numbers in the K-map can be circled multiple times in groups of 2 or 4.
  • A third participant agrees with the previous point, prompting further exploration of additional groupings in the K-map.
  • A later reply expresses frustration over an oversight in their diagram and presents a new expression: BC + AB + AC.
Participants generally agree that the initial expression is not in its simplest form, but there is no consensus on the final simplified expression, as one participant proposes a new form without confirmation from others.
There are limitations regarding the assumptions made about the K-map grouping rules and the specific numbering of the cells, which may affect the interpretation of the simplification process.
mr_coffee
here is my work and picture:
http://img146.imageshack.us/img146/1349/asdfas7hu.jpg
is this the simplest form? Thanks.
if that link is slow, also u can try this one:
http://show.imagehosting.us/show/771..._-1_771087.jpg
My answer would be no, it is not. For the K-Map, circled numbers may be circled again. You can circle in groups of 2 or 4. Thus you can circle as well slots 6-7 and 7-8 in addition to 3-7. Assuming a numbering from 1-8 of the cells left to right then top to bottom.
re
I agree, you can circle adjacent squares more than once. How many more can you find?
ahh, i can't believe i did that, and i freaking drew everything, the diagram,etc, f word. Thanks! I got: BC + AB + AC
  • · Replies 18 ·
  • · Replies 68 ·
11K
  • · Replies 29 ·
