| Thread Closed |
Positive work done by FRICTION? |
Share Thread | Thread Tools |
| Oct9-05, 03:43 PM | #18 |
I believe it's quite problematic that we're given basic mechanics homework papers containing assignments whose quite far-reaching solutions apparently change radically by semantics.
Our professor generally doesn't elaborate. I guess he either 1. assumes that we'll assume what he's assuming or 2. that he wants us to be on slipping ground, and build the foundation first of all things at the beginning of each solution process. The latter is quite problematic. You still haven't answered strictly based on the .pdf-solution; only given an example with static friction, whose analogy you might have asserted, but didn't explain. |
| Oct9-05, 03:43 PM | #19 |
Mentor
| Oct9-05, 03:46 PM | #20 |
Ok, that's one guy convinced. But only one. Everyone else seems to say the opposite. I'm inclined to follow your argumentation here, since it equals my initial thinking, when I thought about the conveyor belt situation, where a system moving relatively to the Earth contains elements moving relatively to each other.
But what level of mechanics are you at? |
| Oct9-05, 03:57 PM | #21 |
Recognitions:
It seems to me that the .pdf solution is fine. The box starts at rest in the lab frame, it is dropped onto the conveyor, the conveyor exerts a force called friction on the box trying to reduce the relative motion, the box speeds up in the lab frame, friction did positive work by increasing the kinetic energy of the box. I think Doc Al is right on this, and I'm a physicist so mechanics is my bread and butter
| Oct9-05, 04:08 PM | #22 |
Recognitions:
There isn't anything magical about this, all it says is that the work done by a force depends on the frame of reference. In the lab frame the block gains kinetic energy meaning positive work is done. In the conveyer belt frame the block loses kinetic energy meaning negative work is done.
| Oct9-05, 04:11 PM | #23 |
My point exactly. I'm gonna write that then.
| Oct9-05, 04:57 PM | #24 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Positive work done by FRICTION?
| Positive or negative work? | Introductory Physics Homework | 4 | ||
| Positive and negative work | Introductory Physics Homework | 5 | ||
| The work of friction forces - and - the total work of systems | Introductory Physics Homework | 20 | ||
| positive/negative work | Introductory Physics Homework | 5 | ||
| work done by friction Help! | Introductory Physics Homework | 12 | ||
