A Finite Line Charge's Electric Field?
The discussion focuses on calculating the x-component of the electric field produced by a uniformly distributed positive charge Q along the x-axis, specifically from x=0 to x=a, at points where x>a. The point charge q is positioned at x=a+r, where r is a positive distance. The key approach involves calculating the electric field from an infinitesimal charge element of Q and then generalizing this to an integral to find the total electric field. The constant k is defined as k=\frac{1}{4\pi\epsilon_0}.
  • Understanding of electric fields and charge distributions
  • Familiarity with calculus, specifically integration
  • Knowledge of Coulomb's law and its applications
  • Basic concepts of electrostatics
  • Learn how to calculate electric fields from continuous charge distributions
  • Study the process of setting up integrals for electric field calculations
  • Explore the concept of infinitesimal charge elements in electrostatics
  • Review the derivation and applications of Coulomb's law
Students and professionals in physics, particularly those studying electrostatics, as well as educators looking for practical examples of electric field calculations involving continuous charge distributions.
adamc637
Positive charge Q is distributed uniformly along the x-axis from x=0 to x=a. A positive point charge q is located on the positive x-axis at x=a+r, a distance r to the right of the end of Q.
Problem:
Calculate the x-component of the electric field produced by the charge distribution Q at points on the positive x-axis where x>a (i.e., r>0) in terms of some or all of the variables k, q, Q, a, and r, where [tex]k=\frac{1}{4\pi\epsilon_0}.[/tex]
I don't know what to do, whether it is to split Q into infinitely small sizes and calculate E field for each small part through an integral or what?!
Where do I get started?
Sounds good to me. How about starting with calculating the x component of the field from a single infinitesmal element? Once you've done this, we can discuss how one might generalize it to an integral.
  • · Replies 16 ·
