Blood transfusion pressure problem where did i go wrong?
  • Thread starter Thread starter mrbling
    Blood Pressure
The discussion revolves around calculating the height required for a blood transfusion bottle based on flow rate and pressure. The user initially calculated a necessary pressure difference of 980 Pa using Poiseuille's equation but made an error by incorrectly interpreting the viscosity of blood. The correct viscosity value is 0.004 kg/m-s, which significantly affects the pressure difference and, consequently, the height of the bottle required to achieve a flow rate of 3.95 cm³/min. The final calculated height of 0.328 m is incorrect due to this oversight.
  • Understanding of Poiseuille's equation for fluid dynamics
  • Knowledge of blood viscosity and its units (Pa-s vs. kg/m-s)
  • Familiarity with pressure calculations in fluid mechanics
  • Basic principles of blood transfusion procedures
  • Review the correct application of Poiseuille's equation in fluid dynamics
  • Learn about the properties of blood, including viscosity and density
  • Study pressure calculations involving hydrostatics and fluid flow
  • Investigate common errors in fluid mechanics calculations
Medical professionals, biomedical engineers, and students studying fluid dynamics or transfusion medicine will benefit from this discussion, particularly those involved in the practical aspects of blood transfusions.
mrbling
Here is the question and my solution (Which is wrong..) my question is.. where did I go wrong?
A patient is to be given a blood transfusion. The blood is to flow through a tube from a raised bottle to a needle inserted in the vein. The inside diameter of the 3.97 cm long needle is 0.406 mm and the required flow rate is 3.95 cm3 of blood per minute. How high should the bottle be placed above the needle?
Use 0.004 Pa and 1050 kg/m3 for the viscosity and density of blood respectively. Assume the blood pressure is 18.0 torr (mm Hg) above atmospheric pressure.
First of all, I need to determine what pressure is necessary to sustain a fluid flow rate of 3.95cm3/min (SI=6.583x10-8 m^3/s). I can use Poiseulle's equation to find the pressure difference necessary. Using the the following variables (in SI):
Pressure diff= 8*n*l*Q/Pi*r^4
where n=.004Pa-s, l=.0397m, Q=6.58x10^-8m^3/s, r=.000406m
I get 980 Pa, which tells me that 980Pa of pressure is necessary to sustain the above flow rate.
Now, I need to worry about the blood pressure. If bp is 18torr above atm, bp=18torr*133Pa/Torr + 101300Pa = 103694Pa.
So the total pressure that I need going into the needle is 104674Pa (980+103694).
Now I use P=P0+rho*g*h to figure out how high i need to raise the bottle.
104674 = 101300 + 1050kg/m^3* 9.8 m/s^2 * H
and get H = .328m
Which is wrong.. can anyone tell me where I went wrong? I can't figure it out.
Thanks
BP = 18? That is one relaxed patient!
for sharing your solution and asking for feedback on where you may have gone wrong. It shows that you are actively trying to learn and improve, which is a great attitude to have in any field.
After reviewing your solution, I believe the error may lie in your calculation of the required pressure difference. While you correctly used Poiseuille's equation, you used the wrong value for the viscosity of blood. The value given for viscosity in the problem is 0.004 Pa-s, which is equivalent to 0.004 kg/m-s. However, in your calculation, you used 0.004 Pa-s instead of 0.004 kg/m-s. This leads to a much higher value for the required pressure difference, which in turn leads to a higher value for the height of the bottle.
To correct this, simply use the correct value for viscosity (0.004 kg/m-s) in your calculation. This should give you a more accurate value for the required pressure difference and the height of the bottle.
I hope this helps and good luck with your future problem-solving!
