Probability Theory - Expected Value.
The discussion revolves around a probability theory problem involving a random variable X with a specified probability mass function. Participants are tasked with finding a constant C, not equal to 1, such that the expected value E[c^X] equals 1.
  • The original poster attempts to calculate E[X] and E[c^X], leading to the equation c^(1-2p) = 1. They express confusion over arriving at c = 1, which is not allowed. Other participants question the original poster's interpretation of the expected value and suggest a different approach to calculating E[c^X] based on the probabilities of X's values.
Participants are actively engaging with the problem, with some clarifying misunderstandings about the expected value calculation. There is recognition of the need to solve a quadratic equation derived from the expected value expression, but no consensus has been reached on the correct approach or solution.
There is a constraint that the constant C cannot equal 1, which is central to the problem and affects the participants' reasoning and attempts to solve the equation.
rad0786
Hey.. I am having some problems with this homework question, i thought perphaps somebody can help me on it.
-- Let X be a random variable with probability mass function
x P(x)
-1 p
1 1 - p
Find the value of the constant C not equal to 1 such that E[c^X] = 1
So this is my work so far. We have E[X] = 1 -2p and E[c^X] = 1 ...
E[X] = 1 -2p
E[c^X] = 1
then c^X = c^(1-2p) = 1 so...
c^(1-2p) = 1
I do the logarithms...
(1-2p)logc = log1
(1-2p)logc = 0
log c = 0
c = 1
but that is no true, since c cannot equal 1. What am i doing wrong?
The only other solution i can see is 1^(1-2p)^-1 = 1/(1-2p)
sorry.. the mass funtion looks awkward above... its actually...
x p(x)
-1 p
1 p-1
You seem to have a completely wrong idea about what's going on here!
No, c^X is not c^(1-2p). That would be cE(x) which is irrelevant.
What your probability function says is that x can have one of only two values: -1 and 1, with probabililty p and 1-p respectively. That means that c^x can have one of only two values: c-1= 1/c and c, with probability p and 1-p respectively. The "expected value" is the sum of the each possible value times its probability: p/c+ c(1-p)= 1. Solve that for c in terms of p.
Hey... I see the error I made now...
for solving... i managed to simplyfy the equation to 0 = (1-p)c^2 - c + p
This is the same as... 0 = (1-p)x^2 - x + p and the idea is to solve for x or p. Believe me, I tried EVERYYTHING to solve this, even the quadratic. I just keep finding my self at a ded end. I know that c=1 works just fine, but the question says that c cannot equal to one.
Anybody have any ideas?
Ive been stuck on this for the whole day... how on Earth do i solve for c?
(1-p)C^2 - C + p = 0 //or// p/C + C(1-p) = 1
I just keep getting 1 as an answer and the questions says C not equal to 1
9K
