Trig Identity: Solving \cos \theta (\tan \theta + \cot \theta) = \csc \theta
  • Thread starter Thread starter cscott
    Identity Trig
The discussion revolves around establishing the trigonometric identity \(\cos \theta (\tan \theta + \cot \theta) = \csc \theta\). Participants are exploring the relationships between tangent, cotangent, sine, and cosine within the context of trigonometric identities.
  • Participants suggest expressing tangent and cotangent in terms of sine and cosine, and finding a common denominator. Others discuss algebraic manipulations and substitutions to simplify the expressions. There are questions about how to proceed after reaching certain forms of the equations.
The discussion is active, with participants providing guidance on how to manipulate the identities and expressions. There is a collaborative effort to clarify steps and approaches, although no consensus has been reached on a complete solution.
Some participants express uncertainty about their abilities in proofs and seek reassurance and further clarification on the steps involved in the identity verification process.
cscott
Can someone please help me establish this identity?
[tex]\cos \theta (\tan \theta + \cot \theta) = \csc \theta[/tex]
So, are you proving this identity?
Express your tangent and cotangent in terms of sine and cosine. Get their LCD... and your numerator becomes a well-known trigonometric identity..
Can you continue from here? :D
The easy ones always get me :\
Thanks!
I can't get this one either:
[tex]\frac{1 + \tan \theta}{1 - \tan \theta} = \frac{\cot \theta + 1}{\cot \theta - 1}[/tex]
I'm so bad at proofs :frown:
For this one, you can either choose to replace tan x by 1/cot x or replace cot x by 1/tan x. Choose either and do some algebriac manipulations while leaving the other side alone.
Or, if that doesn't work for you, substitute tan by sin/cos and cot by cos/sin, then simplify the expressions :smile:
Try, if you get stuck, show us!
I end up with
[tex]\frac{\cos^2 \theta + \sin \theta \cos \theta}{\cos^2 \theta - \sin \theta \cos \theta}[/tex]
or
[tex]\frac{\cot^2 \theta + \cot \theta}{\cot^2 \theta - \cot \theta}[/tex]
How do I continue?
How did you end up with that?
For the LHS:
[tex]\frac{{1 + \tan \theta }}{{1 - \tan \theta }} = \frac{{1 + \frac{{\sin \theta }}{{\cos \theta }}}}{{1 - \frac{{\sin \theta }}{{\cos \theta }}}} = \frac{{\frac{{\cos \theta + \sin \theta }}{{\cos \theta }}}}{{\frac{{\cos \theta - \sin \theta }}{{\cos \theta }}}} = \frac{{\cos \theta + \sin \theta }}{{\cos \theta - \sin \theta }}[/tex]
Now try the RHS :smile:
For the LHS:
Silly me - I just multiplied out the numerator by the reciprocal of the denomenator instead of just canceling out the cosines. If you factor the top and bottom of my expression you end up with what your answer. If I do this using 1/cot = tan I end up with the RHS.
Don't I need to continue with the LHS until I get the right or vice versa?
Well now you have the LHS, the easiest would be trying to get the same starting with the RHS, which will go more or less the same :smile:
Ah, I see. Thank you both of you.
No problem :smile:
