Temperature Rise of the cooling water
The discussion focuses on calculating the temperature rise of cooling water in a Rankine Cycle, specifically using 2000 kg/s of cooling water to cool 36 kg/s of working fluid at a pressure of 10 kPa. Participants emphasize applying the first law of thermodynamics by drawing control volumes around the cooling water and working fluid. Key steps include neglecting kinetic and potential energy, recognizing no internal energy change, and ensuring energy conservation between the control volumes. The calculation of enthalpy is highlighted as a critical step, utilizing databases or specific heat and temperature relationships.
  • Understanding of the Rankine Cycle and its components
  • Familiarity with the first law of thermodynamics
  • Knowledge of control volume analysis in thermodynamics
  • Ability to calculate enthalpy using specific heat and temperature
  • Research methods for calculating enthalpy in thermodynamic systems
  • Learn about control volume analysis in fluid mechanics
  • Explore databases for thermodynamic properties of fluids
  • Study the application of the first law of thermodynamics in heat exchangers
Students and professionals studying thermodynamics, particularly those focusing on vapor power cycles and the Rankine Cycle, as well as engineers involved in thermal system design and analysis.
shaiqbashir
Hi Guys!
well! I am studying vapor powered cycles nowadays. The topic which I am studying currently is The Rankine Cycle. I came across a question in my book . which i want you to help me out.
It is said that in the rankine cycle, in the condenser, 2000 kg/s of cooling water is used to cool a 36 kg/s of working fluid in each cycle.
Now it is asked to find the temperature rise of the cooling water. Now i know the pressure of the fluid after condensation that is 10 kPa. Now please tell me the way to find it out. I am not asking to solve me the question, just asking any hint so that i may be able to do it. Please help me as soon as possible,
In this and all similar analysis, you want to apply the first law of thermodynamics. Drawing control volumes around parts of the system will help to simplify things so you can better apply the first law.
Draw a control volume (CV) around each of the two fluids as they pass each other exchanging heat. You should be able to think of 2 control volumes, one around the water, one around the other fluid. Each of these control volumes has mass flow in, mass flow out, and either heat going in or out.
Applying the first law to each CV, you should notice the following:
1. Kinetic and potential energy can be neglected. This is generally true but you can check it if you have any doubt.
2. There is no fluid stored inside either control volume, so the change in internal energy is zero.
3. There is no work done by or on either control volume.
Once you do this, you should have mass going into each CV which is your enthalpy going in or energy entering the CV. You will also have mass leaving each CV which is the enthalpy going out or energy leaving the CV.
Next, you will have thermal energy either entering or leaving each CV. Energy is entering the water making it hotter, and leaving the other fluid making it cooler.
Now all you need to do is tally up the energy. All energy entering the CV should equal all energy leaving the CV.
One of the problems most students run into is how you calculate the enthalpy. In industry, we have data bases that you can put pressure and temperature in and get enthalpy out. Or you can put enthalpy and pressure in and get temperature out, etc… But you can also calculate enthalpy by using specific heat and temperature.
  • · Replies 28 ·
  • · Replies 16 ·
  • · Replies 26 ·
