Turning Stone into Refractive Glass: Temperature Requirements
The discussion revolves around the temperature requirements for turning stone into refractive glass, exploring the processes involved in glass formation from natural rocks and the conditions necessary for achieving a glassy texture.
  • Some participants question the definition of 'refractive glass' and seek clarification on its meaning.
  • It is noted that natural glass typically forms from rapidly cooled lava, with the melting point dependent on the lava's composition.
  • One participant expresses uncertainty about the possibility of turning normal rock into glass using extreme heat and asks for the required temperature.
  • Another participant asserts that intense heat applied to rocks leads to metamorphosis rather than glass formation, suggesting that a glassy texture is not a typical outcome of this process.
  • It is mentioned that the melting of rocks involves different minerals melting at varying temperatures, which complicates the process of achieving a uniform glassy state.
  • One participant explains that industrial refractive glass is made from pure quartz sand, which is melted rather than formed from natural rocks.
Participants express differing views on the feasibility of turning stone into glass and the processes involved, indicating that multiple competing perspectives remain unresolved.
The discussion highlights the complexity of rock melting and glass formation, with limitations in assumptions about the types of rocks and their mineral compositions affecting the outcomes discussed.
randy23
What temperature does stone have to reach for it to turn into refractive glass?
What do you mean when you say 'refractive glass'?
The usual way for natural glasses to form is to cool lava (usually basaltic, but not nessecarily) so quickly that crystals do not have time to form. The temperature at which this happens is dependent on the lava composition, as this sets its melting point.
Sorry for not explaining very well. Is it possible to turn normal rock into glass using extreme heat? If so, at what temperature would it have to be?
Not as far as I know. The way I've described is the only way I know that natural glass forms. When intense heat is applied to rocks, they undergo metamorphosis, in which their mineral structure is altered (extreme pressure often, but not always present during metamorphisis too.)
Resulting rocks show a vareity of textures, depending on the specific properties of the original rock and the conditions under which the change occurred, but a glassy texture is not one of them. The page I linked to has more detailed information if you are interested.
If temperatures continue to increase, rock will melt completely and eventually cool to form an igneous rock such as granite.
The majority of rocks are composed of a variety of minerals, each with a distinct melting point. When you raise the temperature of a rock certain minerals will melt first. This is the reverse of the process by which a magma solidifies. [One of the reasons there are so many kinds of igneous rock is that as the first minerals separate from the melt they change its composition.]
If a magma is cooled suddenly, as matthyaouw has noted, then it will yield a glassy composition.
Refractive glass, by which I think you may mean transparent glass, is made industrially by taking very pure quartz sand and melting it. This sand is generally taken from dunes rather than from sandstone.
  • · Replies 25 ·
