Tangent line at y = 9/sqrt(1+x)
The discussion revolves around finding the y-intercept of the tangent line to the function y = 9/sqrt(1+x) at the point where x = 9. Participants are exploring the relationship between derivatives and tangent lines in the context of calculus.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to find the slope of the tangent line using the derivative and the corresponding point on the graph. There are questions about the relationship between the derivative and the tangent line, as well as the process to find the y-intercept once the slope and point are known.
The conversation includes attempts to clarify the steps needed to find the y-intercept, with some participants offering guidance on using the slope and point to formulate the equation of the tangent line. There is a recognition of the need to evaluate the derivative at a specific point to determine the slope.
Participants express confusion regarding the calculations and the relationship between the derivative and the tangent line, indicating a need for further exploration of these concepts. There is a focus on ensuring all necessary components (slope and point) are identified to proceed with the problem.
volc
Find the y-intercept of the tangent line to the graph of y = (9)/sqrt(1 + x) at the point where x = 9.
I used the quotient rule to find the derivative.
I found that to be (-9/2(1+x)^-1/2)/(1+x) But then I am totally clued out...
Thanks for helping me out.
volc
What is the relationship between the derivative and the tangent line?
You need to assess what you have:
1. slope of the line you want to construct
2. a point that the line goes through
These 2 pieces of information should allow you to write the equation of the line. Once you have the equation, you can find the y intercept.
Derivative of function = slope of the tgt line.
I don't understand what you mean. :/
If you have the equation of the tangent line, you can find the y-intercept, right? You need therefore to find the equation of the line. You have two pieces of information, the slope of the line and a point the line passes through. Is this suffucient to write an equation for the line?
A line in the x-y plane is given by y=mx+b (I assume you know that). Taking the derivative and plugging in your x=9 will give you m. You still need to find b, which is precisely what the question asks for. If I were you, I would plug x=9 into your original equation, find your y value, then substitute both of those into y=mx+b and solve for b.
Alex
(-9/2(1+x)^-1/2)/(1+x) = slope of the tgt line right ? And the equation for the tangental line is y= mx + b, where m = (-9/2(1+x)^-1/2)/(1+x). To find y I need to find b and I can't seen to be able to find b.
That is m(x). To find the slope at a point, you need to plug that x-value in!:smile: Do you understand why?
Alex
When I plug in the x value (-9/2(1+x)^-1/2)/(1+x) I get:
(-9/2)((10)^-3/2) and this is x or m(x) ?
volc
volc
What do you think it is? Remember that the derivative at a point will be the slope (m) of the graph at that point. Now, you have an x-value given to you. You need to find the cooresponding y-value so that you have a slope and a point. You can find an equation of a line using a point and the slope, thus find the y-intercept.
If I were you, I'd go back and read up on what a derivative actually means geometrically.
Alex
