How Does the Height of a Sand Pile Change as It Grows?
  • Thread starter Thread starter bard
    Related rates
The discussion focuses on the rate of change of the height of a sand pile shaped like a cone, where sand is added at a rate of 9π cubic feet per minute. The relationship between the diameter and height is established as the diameter being three times the height. The calculations involve differentiating the volume formula V = (1/3)πr²h, leading to the conclusion that the height is changing at a rate of 27/792 feet per minute when the height is 12 feet. The correct approach requires accounting for the relationship between the radius and height during differentiation.
  • Understanding of calculus, specifically differentiation techniques.
  • Familiarity with the geometric properties of cones.
  • Knowledge of related rates in physics and mathematics.
  • Ability to manipulate algebraic expressions involving variables.
  • Study the concept of related rates in calculus.
  • Learn about the geometric properties of cones and their volume calculations.
  • Practice differentiation of composite functions.
  • Explore real-world applications of related rates in physics problems.
Students studying calculus, mathematics educators, and professionals in fields requiring knowledge of geometric modeling and related rates, such as engineering and physics.
bard
Sand is falling onto a cone-shaped pile at the rate of 9pi cubic feet per minute. the diameter of the base is always 3 times the height of the cone. At what rate is the height of the pile changing when the pile is 12 feet high.
work:
dV/dt=+9 ft^3/min
d=3h then r=3h/2 dr/dt=(3/2) dH/dt
Find dH/dt when h=12 ft. which means r=18 ft
V=pi(r)^2h/3
dV/dt=(pi/3)(r^2*dh/dt+h*2r*(3/2)dH/dt)
9pi ft^3/min=(pi/3)(r^2*dh/dt+h*2r*(3/2)dH/dt)
would this be the correct way to find the answer and get dH/dt i get 27/792 ft/min is this correct?
You nearly have it right. However if you have two variables r and h, when differentiating you would've needed to have a dr/dt as well, since r is also a function of t. However, to make things easier, you can sub in 2r = d = 3h.
V = 1/3(base)(height)
V = pi/12(diameter^2)(height)
V = pi/12(9height^2)(height)
V = 9pi/12(height^3)
Now you can easily differentiate both V and h with respect to time.
