Capacitors in Parallel and Series
The discussion revolves around a circuit involving capacitors in both series and parallel configurations. The original poster has calculated the total capacitance but is seeking assistance in determining the charge on each capacitor given a potential difference of 300 V between two points in the circuit.
  • Mixed
  • The original poster attempts to apply known relationships between charge and capacitance but expresses uncertainty about the next steps after calculating total charge. Other participants question the clarity of the circuit representation and suggest different methods for analyzing the circuit.
Participants are exploring various interpretations of the circuit layout and discussing the application of voltage division and charge calculations. Some guidance has been offered regarding the use of formulas for charge and voltage, but there is no explicit consensus on the approach to take next.
There are indications of confusion regarding the circuit diagram, and participants are attempting to clarify the arrangement of the capacitors. The original poster has mentioned specific values for capacitance and total charge, but the discussion reflects uncertainty about how to proceed with the calculations.
meadow
Hello. I have a brain fart and this combination circuit has me stumped. Here is a crude representation of the circuit. I had no problem finding the total capacitance (1.34uF), but the second part asks you to find the charge on each of the capacitors, assuming that the potential difference between b and a is 300 V.
2uF 5uF
a.---| |----- ----.b
3uF ------||----------
1uF
Ok, I know that the Q2=Q5 and Q3=Q7. The total charge is 402 uC, so Q3=Q7=402uF. Where do I go from here. I have tried all combinations...
Okay, I don't see that circuit of yours. Could you go maybe by circuit flow :P
oops!
The circuit from point a goes to a capacitor of 3uF, then leads to 2 capacitors in series (2uF and 5uF) that are together parallel to a capacitor of 1uF. From the parallel circuit section you get to point b. Does that make sense? I tried to draw it out...but I guess it didn't work:) Thanks!
So 3uF+( (2uF + 5uF)//(1uF ) ?
Your diagram just suggests otherwise. Anyway.
To calculate the charge on a capacitor in steady state, you use:
Q = CV
The only problem then would be finding V across each capacitor.
The voltage division rule applies to capacitors as V1 = C2/(C1+C2)
  1. With equivalent capacitance, first calculate charge with Q=CV.
  2. Then calculate voltage across 3uF using V=Q(as obtained above)/3uF
  3. Voltage across the parallel combination of 1uF with series combination of 2uF and 5uF will Vab (300v)-V(across 3uF, as obtained above, in step 2). This will be voltage across 1UF.
  4. Using voltage division formula calculate voltages across 2uF and 5uF; sum of voltages across 2uF and 5Uf will be same as voltage across 1uF
