Particular differnetial solution
  • Thread starter Thread starter Phymath
The discussion focuses on solving the particular solution of the damped harmonic oscillator driven by the force F(t) = F_0e^{-\alpha t}cos(\omega t). The participants emphasize the importance of using the hint provided, which involves expressing the force in terms of complex exponentials. The solution approach includes substituting x(t) = De^{Bt - i \phi} and solving the corresponding differential equation x'' + 2 \gamma x' + \omega^2 x = 0. The conversation highlights the necessity of finding a single solution to the inhomogeneous equation to complete the solution process.
  • Understanding of damped harmonic oscillators
  • Familiarity with differential equations, specifically second-order linear DEs
  • Knowledge of complex numbers and their applications in solving differential equations
  • Experience with exponential functions and their properties
  • Study the method of undetermined coefficients for solving inhomogeneous differential equations
  • Learn about the Laplace transform and its application in solving differential equations
  • Explore the concept of resonance in damped harmonic oscillators
  • Investigate the use of complex exponentials in solving physical systems
Students and professionals in physics and engineering, particularly those focused on dynamics and systems analysis, will benefit from this discussion. It is also valuable for anyone studying differential equations and their applications in real-world scenarios.
Phymath
solve for the particular solution of the damped harmonic oscillator driven by the damped harmonic force
[tex]F(t) = F_0e^{-\alpha t)cos(\omega t)[/tex]
(Hint: [tex]e^{-\alpha t} cos(\omega t) = Re[e^{-\alpha t + i \omega t}] = Re[e^{B t}][/tex] where [tex]B = -\alpha + i \omega[/tex]. Find the solution in the form [tex]x(t) = De^{B t - i \phi}[/tex], i don't have much diff e q the only thing i think of doing is the following..
[tex]x'' + 2 \gamma x' + \omega^2 x = 0[/tex]
[tex]c^2 + 2 \gamma c + \omega^2 = 0[/tex]
[tex]x(t) = C_1 e^{-(\sqrt{\gamma^2 - \omega^2}+\gamma)t} + C_2 e^{(\sqrt{\gamma^2 -\omega^2}-\gamma) t}[/tex]
no idea where to go from here... any help would be awesome
I forget what the damped harmonic oscillator DE is but it looks like you solved the homogenous part of the equation. Now all you need is a single solution to the inhomogenous equation.
To do this, follow the hint they've given you, take a wild chance and just substitute [itex]Re[e^{Bt}][/itex] for x. You won't get the right answer (that is, get F(t) on the RHS of your DE), but you should get something that is proportional and that will give you enough hint to get you through.
Good luck. It's a lot of work. Feel proud. Time for me to get some sleep.
Carl
