How to Calculate Tension in a Two-Block System with Upward Acceleration?
  • Thread starter Thread starter babbagee
The discussion revolves around calculating the tension in a two-block system that is accelerating upward. The original poster seeks guidance on how to approach the problem, specifically regarding the tension in the lower rope (T2) while considering the forces acting on both blocks.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster expresses uncertainty about how to begin, questioning whether T2 should equal the force applied on block one plus the weight. Some participants suggest applying Newton's 2nd law to analyze the forces acting on each block, while others propose specific equations for tension based on the forces involved.
Participants are exploring different interpretations of the problem and discussing the application of Newton's laws. Some have drawn free body diagrams to visualize the forces, and there is an ongoing dialogue about the correct approach to find the net forces acting on each block.
There is a focus on ensuring that the net forces are correctly identified and that assumptions about the forces acting on the blocks are critically examined. The discussion does not yet reach a consensus on the specific calculations or methods to be used.
babbagee
Hello
The question is
The blocks are now accelerating upward (due to the tension in the strings) with acceleration of magnitude a.
Find T2, the tension in the lower rope.
I really don't know where to start with this one. Would T2 equal the force that is applied on block one plus the weight that is pulling down. Point me in the right direction please.
Thanks
What is the difficulty you are having, or what about the problem do you understand or not understand so far. What principles do you think you should use?
Would the tension be T2 = M1g + (M1 + M2)a
beccause there is a downward force of gravity and then an upward force which is acting on both block 1 and 2. So their force would be (M1 + M2)a and the tension would be the sum of these two forces.
Rather than try to solve it in your head, why not apply Newton's 2nd law to each block. What forces act on each?
Block one
W=mg
T1=ma
force of block 2 pulling on block 1 which is the opposite of T2, right
Block two
W=mg
T2=ma
I drew the free body diagrams for the two blocks and these are the forces I came up with.
Careful: Don't equate a specific force with ma. Newton's 2nd law says that the net force will equal ma.
The forces on block 1: its weight, the tension T1, the tension T2.
The forces on block 2: its weight, the tension T2.
I'll leave it to you to specify the direction of these forces. Now find the net force on each block and apply Newton's 2nd law.
  • · Replies 38 ·
  • · Replies 52 ·
