Need basic understanding of force and friction
  • Thread starter Thread starter Balthamos
    Force Friction
The discussion revolves around understanding the concepts of force and friction, particularly in the context of Newton's second law of motion (Fnet = Ma). Participants express confusion regarding the application of units and the role of friction in problem-solving scenarios involving forces acting at angles.
  • Participants discuss the standard units for force, mass, and acceleration, questioning how to apply these in dimensional analysis. There is an exploration of the nature of friction, including static and kinetic friction, and how to incorporate friction into equations when solving problems.
The discussion is active, with participants sharing insights about the relationship between applied forces and friction. Some guidance has been provided regarding the calculation of net forces and the effect of angles on normal force, though there is still a lack of consensus on how to fully integrate these concepts into problem-solving.
Participants mention specific problem constraints, such as the mass of the sled, the angle of the pulling force, and the frictional force that needs to be overcome. There is a noted urgency due to an upcoming test, which may influence the depth of understanding being sought.
Balthamos
Hello,
I am having some trouble understanding this whole concept about friction as well as force (Newton's 2nd law). What I was told is that Fnet=Ma, which I'm guessing stands for sum force = mass * acceleration.
What I wasn't told is how the units are dealt with. I am very used to dimensional analysis, and that isn't helping me one bit. What exactly do these units need to be? I was thinking:
F=N
M=kg
a=m/s^2
As for friction, I'm not even sure where to begin with that. I don't think that I was given any specific formula.
Thanks,
~Balthamos
That's Newton's 2nd law of motion. It applies for all forces, not just friction.
F=N
M=kg
a=m/s^2
Those are the standard units. Note that N = kg-m/s^2.
As far as dimensions go, Force has dimension of [itex]M L T^{-2}[/itex].
Friction is a contact force between two surfaces that resists slipping between those surfaces. It has the same units as any force. Generally, there are two kinds of frictions you'll have to worry about: static friction, in which the surfaces do not slip, and kinetic friction, in which the two surfaces slide over each other. Look them up!
Yes, so you have: N=kg*m/s^2
What about friction?
I know what friction is, but how am i actually supposed to implement it into the equation? Like in a problem that asks: Find the the acceleration of the 10 kg sled w/ force of 180 N (also pulling at an angle, but I can figure that out), if the friction to be overcome is 15N (if F > static friction?)
So I would say:
F=Ma
180=10a
a=18 m/s^2
Then what? Where do I stick in the friction? Would I subtract 15N from 180N because of the resistance or what?
~Balthamos
The friction acts parallel to the surfaces, opposing the motion of the sled. You will include it as one of the forces acting on the sled.
I think you would substract the 15N from the x component of the 180N applied force.
All they give me is the following:
sled=10kg (pulled across level ground)
sled's rope makes 30 degree angle with ground
rope pulls on sled with 180N
What is this [tex]F_f = \mu F_N[/tex] you speak of? Would that be the total friction = something * net force?
~Balthamos
Disregard that equation if you haven't learned it yet.
I would find the x component of the applied force, and substract it the 15N force of friction from it to get the net force in the x direction.
No, please, explain. There are problems on the worksheet that ask for coefficients of friction, and my teacher doesn't explain everything well enough. Sooner or later, she will tell us about this equation (hopefully within the 2 days left before the test)
~Balthamos
OK, well if you have a force acting at an angle, then the y-component will affect affect the force of friction because it changes the normal force.
So,
[tex]\begin{align*}<br /> F_y &= F \sin \theta \\<br /> F_x &= F \cos \theta \\<br /> \end{align*}[/tex]
[tex] \begin{align*}<br /> F_N &= mg - F_y \\<br /> F_f &= \mu F_N \\<br /> \Sigma F_x &= F_x - F_f = ma \\<br /> \end{align*}[/tex]
If say I was pulling a sled with the rope at an angle I would be slightly lifting the sled which means it's pushing less against the ground and the ground pushes less back at it (normal force). A change in normal force affects friction "through" [itex]F_f = \mu F_N[/itex] where [itex]\mu[/itex] is calculated experimentaly. You see?
  • · Replies 20 ·
  • · Replies 21 ·
