What Are the Variables in a Photosynthesis Experiment Using Phenol Red?
The discussion focuses on identifying the variables in a photosynthesis experiment using phenol red to determine if plants absorb carbon. The independent variable is the type of plant, the dependent variable is the amount of carbon absorbed, and the control variables include the concentration of phenol red and the volume of water in the test tubes. Participants emphasize the importance of clearly defining these variables to ensure accurate experimental results.
  • Understanding of independent, dependent, and control variables
  • Basic knowledge of photosynthesis processes
  • Familiarity with phenol red as a pH indicator
  • Experience with experimental design in biology
  • Research the role of phenol red in photosynthesis experiments
  • Learn about the methods for measuring carbon absorption in plants
  • Explore experimental design principles in biological research
  • Investigate the effects of different plant species on photosynthesis rates
Students conducting biology experiments, educators teaching plant physiology, and researchers interested in photosynthesis and experimental design.
ren347
Photosynthesis - urgent help!
I am doing an experiment where there are two plants in test tubes in water which contains phenol red. The experiment is to find out if plants absorb carbon. What are the independent, dependent and control variables?
You need to provide some of your own work first. How do you define (or what are the differences between) an independent, dependent, and control variable?
Can you list all the variables in your experiment, even if you aren't sure which kind they are yet? Otherwise, you have not yet provided enough information for us to help you.
15K
9K
10K
