Calculating Acceleration of a Car using Power and Time
The discussion focuses on calculating the acceleration of a car with a mass of 880.0 kg, using the net power output of 3700.0 W at a speed of 13.8 m/s. Initially, the user attempted to derive acceleration using the equation P = change in work / t, leading to an incorrect time calculation of 22.7 s. The correct approach involves using the differential form of power, P = F * v, to find the force and subsequently the acceleration, which is determined to be 0.607 m/s².
  • Understanding of Newton's Second Law of Motion
  • Familiarity with the concepts of power and work in physics
  • Basic knowledge of calculus for differential equations
  • Ability to manipulate and solve algebraic equations
  • Study the relationship between power, force, and velocity in physics
  • Learn how to apply Newton's Second Law to real-world scenarios
  • Explore the concept of differential equations in physics
  • Investigate the effects of friction and air resistance on vehicle acceleration
Students studying physics, automotive engineers, and anyone interested in the mechanics of vehicle acceleration and power dynamics.
Punchlinegirl
A car of mass 880.0 kg accelerates away from an intersection on a horizontal road. When the car speed is 13.8 m/s, the net power which the engine supplies is 3700.0 W ( in addition to the extra power required to make up for air resistance and friction). Calculate the acceleration of the car at the time.
I used the equation for power. P= change in work/ t
3700= (1/2)mv^2 / t
3700=83793.6 t
I solved for t to get 22.7 s.
I then used the equation for acceleration, change in v/ change in t
a= 13.8-0/ 22.7-0
and got the a to be .607 m/s^2
This wasn't right.
Can someone help me out? Thanks
You have to use the differential form: [tex]P = \frac{dW}{dt} = F v[/tex]. So the power is the force times the velocity, can you now find the acceleration?
Ok I got it.. thanks a lot!
  • · Replies 20 ·
