Solving a Cube Problem with Constant Coefficients
The discussion focuses on solving the differential equation y''' + y' + 2y = 0 using the method of constant coefficients. The characteristic equation derived is r³ + r + 2 = 0, with -1 identified as a root. The process of polynomial long division is utilized to factor the characteristic polynomial, leading to the identification of the quadratic form for the remaining roots. The discussion emphasizes the importance of recognizing roots and applying polynomial division effectively.
  • Understanding of differential equations, specifically linear homogeneous equations.
  • Familiarity with the method of constant coefficients in solving differential equations.
  • Knowledge of polynomial long division techniques.
  • Ability to identify and verify roots of polynomials.
  • Study the method of undetermined coefficients for solving non-homogeneous differential equations.
  • Learn about the Routh-Hurwitz criterion for stability analysis in differential equations.
  • Explore the application of Laplace transforms in solving linear differential equations.
  • Investigate the use of numerical methods for approximating solutions to complex differential equations.
This discussion is beneficial for students and professionals in mathematics, engineering, and physics who are dealing with differential equations and seeking to enhance their problem-solving skills in this area.
mathmike
hi all i have a bit of a problem here, it has to do with completing the cube.
here is the problem
y''' +y' + 2y = 0
i am trying to sove by the methoed of constant coefficients
So your characteristic equation is r3+ r+ 2= 0.
One of the things I notice immediately is that (-1)3+ (-1)+ 2= 0. Does that help?
So how do you divide r+1 into [itex]r^3+r+2[/itex]?
Well r goes into [itex]r^3, r^2[/itex] times right? So that means:
[tex]r^2(r+1)=r^3+r^2[/tex]
and:
[tex](r^3+r+2)-(r^3+r^2)=-r^2+r+2[/tex]
Ok, we got the first one: [itex]r^2[/itex]
Now, how do you divide r+1 into [itex]-r^2+r+2[/itex]
Keep doin' that to get to the quadratic form of the remaining roots, remainder at end is 0 if -1 is a root. You know how to do this right?
