Solving a Parallel-Plate Air-Filled Capacitor Problem
  • Thread starter Thread starter mr_coffee
    Capacitor
The discussion focuses on solving a problem related to a parallel-plate air-filled capacitor with an area of 38 cm² and a plate spacing of 2.0 mm, charged to a potential difference of 450 V. Key calculations include capacitance, charge magnitude, stored energy, electric field, and energy density. The correct approach to find the electric field is using the formula V = E × distance, which simplifies the calculations significantly. The user initially struggled with the electric field calculation but resolved the issue by applying the correct relationship between voltage, electric field, and distance.
  • Understanding of capacitor fundamentals
  • Familiarity with electric field equations
  • Knowledge of capacitance calculations
  • Basic principles of energy storage in capacitors
  • Study the derivation of capacitance for parallel-plate capacitors
  • Learn about energy density in electric fields
  • Explore the relationship between electric field, voltage, and distance
  • Practice problems involving capacitors and their properties
Students and professionals in physics and electrical engineering, particularly those studying capacitors and their applications in circuits.
mr_coffee
Hello everyone. I can't get the 2nd to last question on this problem...
It says:
A parallel-plate air-filled capacitor having area 38 cm2 and plate spacing 2.0 mm is charged to a potential difference of 450 V. Find the following values.
(a) the capacitance
correct check mark pF
(b) the magnitude of the charge on each plate
correct check mark nC
(c) the stored energy
correct check mark µJ
(d) the electric field between the plates
wrong check mark V/m
(e) the energy density between the plates
J/m3
So I figured because the capacitor is a conductor, i know that the e-field just outside a conductor is E = Area Charge Density/Eo or
E = (Q/A)/Eo;
E = (7.57nC)/(.0038cm^2)/8.85e-12 = 225096639 N/C.
Which was wrong, any ideas why? Thanks.
It says:
(a) the capacitance
J/m3
E = (Q/A)/Eo;
I didn't check the numbers but the approach should be (about) right.
However, you're making life difficult: potential is E-field integrated over distance. Now in a parallel plate cap, the E-field is supposed to be constant, so this reduces to V = E x distance. You know the potential difference over the plates and their distance...
THank you so much! that worked great and was much easier, i must have messed up in the calculations! :biggrin:
  • · Replies 18 ·
  • · Replies 20 ·
  • · Replies 26 ·
