How Do You Calculate E in Mica for a Capacitor?
  • Thread starter Thread starter mr_coffee
The discussion focuses on calculating the electric field (E) in a mica dielectric for a parallel-plate capacitor with a capacitance of 60 pF and a plate area of 130 cm². The dielectric constant (k) for mica is specified as 5.4. The initial calculation for E using the formula E = [Q/A]/(k*Eo) yielded an incorrect result of 1.609 V/m. The correct approach involves accurately determining the charge (Q) using the relationship Q = C * V, where C is the capacitance and V is the voltage across the capacitor.
  • Understanding of parallel-plate capacitor theory
  • Familiarity with dielectric materials and their properties
  • Knowledge of capacitance calculations
  • Basic principles of electric fields and charge distribution
  • Review the formula for calculating electric fields in dielectrics
  • Learn about the properties of mica as a dielectric material
  • Explore advanced capacitor design and optimization techniques
  • Investigate the effects of varying voltage on capacitance and electric field strength
Electrical engineers, physics students, and anyone involved in capacitor design and analysis will benefit from this discussion.
mr_coffee
A parallel-plate capacitor has a capacitance of 60 pF, a plate area of 130 cm2, and a mica dielectric ( = 5.4). At 60 V potential difference, calculate the following values.
(a) E in the mica
wrong check mark V/m
(b) the magnitude of the free charge on the plates
C
(c) the magnitude of the induced surface charge on the mica
C
I tried the following:
E = [Q/A]/(k*Eo);
E = (1e-12/.013)/(5.4)(8.85e-12);
E = 1.609 which is wrong.
I got Q by the following: C = QV; Q = C/V; 60e-12/60 = 1e-12
Sorry for the late reply. If you're still working on this then check out the websites I gave you in this thread and see if you don't have better luck.
  • · Replies 18 ·
