What equations describe the behavior of real gases beyond PV=nRT?
The discussion focuses on the equations that describe the behavior of real gases beyond the ideal gas law, PV=nRT. Participants explore various equations of state, their derivations, and the conditions under which they may be applicable, including theoretical and practical considerations.
  • Some participants note that the ideal gas law is only applicable to ideal gases and inquire about suitable equations for real gases.
  • One participant introduces the Van der Waals equation as a well-known equation of state for real gases, explaining its derivation and the significance of the constants a and b.
  • Others mention that there are more precise equations than Van der Waals, such as Beattie-Bridgeman and Benedict-Webb-Rubin, but caution that these equations become increasingly complex.
  • Another participant suggests that the ideal gas law is often sufficient at high temperatures and low pressures, with additional considerations for polyatomic gases.
  • One participant emphasizes the historical context of the Van der Waals constants a and b, noting that Van der Waals himself did not intend for them to be treated as constants.
  • There is mention of computational and numerical methods being used to determine equations of state for real fluids, particularly in fields like chemical engineering and condensed matter physics.
Participants express a range of views on the applicability of the ideal gas law and the complexity of alternative equations. There is no consensus on a single best approach, and multiple competing models and opinions remain present in the discussion.
Some limitations are noted regarding the conditions under which the ideal gas law is applicable, as well as the complexity and practicality of using more precise equations for real gases. The discussion also highlights the challenges in accurately modeling certain fluids, such as water.
newton1
the ideal gas law PV=nRT only can used on the ideal gas, right?
if the we want consider the real gas...
what equation should we used??
Science news on Phys.org
The most famous 'real' gas equation of state is the so-called Van der Waals equation
(P+a*(n/V)^2)(V-nb)=nRT
that can be derived by ideal gas equation substituting
V->V-nb
P->P+a*(n/V)^2
The first substitution compensate for the volume occupied by each molecule (we can think of b as the volume occupied by a mole of gas at 0 Kelvin)
The second substitution compensate for the internal energy density due to intermolecular interaction
a and b are considered constants dependent on the gas only.
You can note that the equation depends on P, T and V/n only, once a and b are fixed.
Try and search on the web for Van der Waals equation...
There are other equations also which are more precise than Van der Waals.
The problem is, they are get more and more complex as the precision gets higher. For many applications, Van der Waals is sufficient.
Examples:
Beattie-Bridgeman
P=RuT/v2*(1-c/(vT3))*(v=B)-A/v2
Benedict-Webb-Rubin
P=RuT/v + (B0RuT - A0 - C0/T2)*1/v2 + (bRuT - a)/v3 + a* α / v6 + c/(v3T2)*( 1 + γ / v2)* e- γ / v^2
(Don't ask me how to apply those... I don't even claim to know...)
in fact, the ideal gas law is usually sufficient too - especially at high temps and low pressures (if you can arrange both) - just allow for extra degrees of freedom in the specific heat if its polyatomic.
to add more detail, there are various levels of thermodynamics through to statistical mechanics that you can apply, if needed - you can model for the "exact" interaction your gas has (in prinicple - these things are hard to solve sometimes, and you'll probably have to use perturbation theory)
for "maximum realness", you'll need Quantum Stat-Mech, but that is probably serious overkill.
Joe
Yep, in general most situations where the pressure < 150 bar and the temperature > 200K are very accurately modeled by the ideal gas law.
- Warren
More a historical curiosity than anything else:
van der Waals never really wanted a and b to be taken as constants, in fact, if you look at his later work in the area, he sought to see how they varied with changing parameters. However, it tends to be something that is not overly productive and has long since fallen by the wayside.
Back on topic...
A good bit of determining equations of state for real fluids is done computationally/numerically, with the algebraic expression extracted after fitting the data. While you not unexpectedly see this in chemical engineering, you also see this quite a bit in condensed matter/chemical physics where we still can't seem to model water accurately all the time. :wink: A good bit of the interest in formulating better quality models of fluids is due to the interest in biological systems, where figuring out solvation can be a non-trivial exercise.
  • · Replies 35 ·
  • · Replies 20 ·
  • · Replies 0 ·
