Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image material property proof load Share It Thread Tools Search this Thread image
Old Oct12-05, 07:36 AM                  #1
chandran
chandran is Offline:
I got a material property data for a steel as follows.
1.0.2% of proof load 358kg
2.0.2% of proof stress 28.64(kg/sqmm)
My questions are
1)what is proof load
2)what is 0.2% of proof load. Why 0.2%? Why not 0.3%
3)How this proof load is arrived while testing the specimin in a universal tensile testing machine?
Old Oct12-05, 01:25 PM                  #2
FredGarvin
FredGarvin's Avatar
FredGarvin is Offline:
Recognitions:
PF Contributor PF Contributor
Proof load is usually another term for the load associated with they yield point. Since it is a steel, it is customary to establish the elastic portion of the stress-strain curve and thus the yield point at a .2% offset. It is my understanding that .2% was agreed upon to use as the offset because not all materials have a distinct yield point.
Take a look here (scroll down to measures of yielding): http://www.key-to-steel.com/Articles/Art43.htm
Old Oct13-05, 09:15 AM                  #3
Astronuc
PF Mentor
Astronuc's Avatar
Astronuc is Offline:
Fred nailed this one right on!
If one checks a glossary in a reference book, one will find -
proof load
A predetermined load, generally some multiple of the service load, to which a specimen or structure is submitted before acceptance for use.
However,
proof stress
(1) A specified stress to be applied to a member or structure to indicate its ability to withstand service loads. (2) The stress that will cause a specified small permanent set in a material.
And it is the second definition which applies here.
IIRC, 0.1% strain offset has also been used in addition to the 0.2% offset, in the US. According to ASM's "Atlas of Stress-Strain Curves", in the UK (and perhaps outside of North America), offset yield strength is referred to as proof stress, and 0.1% or 0.5% is used.
The point of choosing 0.2% is that it is easier that 0.1% and not as much as 0.5%. Using the offset "avoids the practical difficulties of measuring the elastic or proportional limit" of a material. This is not so much a problem these days with digitally controlled tensile test systems, but it was significant 25 or more years ago before high quality digital electronics were available.
The idea was to get as close as reasonably possible to the elastic limit.
Old Oct13-05, 12:22 PM                  #4
Cyclovenom
Cyclovenom's Avatar
Cyclovenom is Offline:
Recognitions:
Homework Helper Homework Helper
Well, when one a material doesn't has an obvious fluency point, and it has great unit strains after it has exceeded its proportional limit, you can get an arbitrary fluency stress by that method, the offset method. It's basicly a straight line on the stress-strain diagram, paralell to the initial linear part of the curve, but it displaces certain standard unit strain, in this case 0.2%. The intersection of the displaced line with the curve defines the fluency stress. This stress is obtained arbitraly and it's not a physical property of the material. However, it can be used as the fluency stress of the material.
image image
Reply
Thread Tools
Similar Threads for: material property proof load
Thread Thread Starter Forum Replies Last Post
What is material property orientation in orthotropic materials? mikewinifred Atomic, Solid State, Comp. Physics 1 Jun13-08 10:09 AM
Proof of integral property tronter Calculus & Analysis 3 Mar6-08 04:00 AM
Proof of Integral Property WHOAguitarninja Calculus & Beyond 2 Dec2-07 03:26 PM
stress-strain relation material property chandran Classical Physics 11 Sep8-06 09:14 AM
I need a proof for this binomial property. T.Rex Number Theory 6 Nov30-04 06:39 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
