How far did this football go, vector problem
  • Thread starter Thread starter mr_coffee
    Vector
The problem involves projectile motion, specifically analyzing the trajectory of a shot put thrown at an angle of 45 degrees with an initial speed of 43 ft/sec from a height of 7 ft. The questions focus on the shot's position after 2 seconds, its maximum height, and where it lands.
  • Participants discuss the equations of vertical motion and the inclusion of initial height in calculations. There is confusion regarding the height after 2 seconds versus the maximum height of the projectile.
Some participants have offered clarifications on the equations used and the significance of initial conditions. There is ongoing exploration of the differences between the calculated height at a specific time and the maximum height of the projectile.
Participants are working under the constraints of homework rules, which may limit the information they can share or seek. There is also a noted discrepancy between the calculated values and those provided in the textbook.
mr_coffee
Hello everyone I'm studying for an exam and this problem is a plug in chug probelm but is giving me troubles...
An athlete throws a shot at an angle of 45 to the hornizontal at an intial speed of 43 ft/sec. It leaves his hand 7ft above the ground.
(a) where is the shot 2 seconds later
(b) how high does the shot go?
(c) where does the shot land?
here is my work and my confusion.
http://img291.imageshack.us/img291/3535/lastscan7as.jpg
THe above is the correct answers and below are the answers i got, I'm confused on why my part (a) the height above the ground, isn't what hte book has, also for part b, it isn't even close to what the book has and im' not sure on how i would approach part c, any help would be great.
I think you're making the simple mistake of missing a term from your equation of vertical motion.
As for (c), it's a matter of figuring out how long the shot is in the air.
vertical motion is stated in the book as:
y = (vosin(angle))t - .5gt^2 and that's what i used
You've almost got the answer for (a) - you just slipped up on the arithmetic. 7ft - 3.18ft = 3.8 ft to 2 s.f.
As dylanm says the height the projectile is launched at is usually included in the initial equation so you would have:
y(t) = h + ut*sin(angle) - 0.5gt^2
ohhh! thanks! what's the ut stand for? so i should have like:
y(t) = 7+ut*sin(45)-.5(32)(2)^2;
Sorry should have said, u is the initial speed of the particle and t is the time in seconds. So we have:
y(2) = 7 + 43*2*sin(45) - 0.5*32*2^2 = 3.8 ft to 2 s.f.
ahh thank u! :)
Why does the book have an answer of 21.4 ft for how high it goes when this shows it went 3.8?
Because the book is asking for the maximum height reached by the projectile over its entire flight and not the height the projectile reached after being in the air for 2 seconds.
  • · Replies 50 ·
  • · Replies 0 ·
  • · Replies 26 ·
