Calculating Work Done on a Train with Jet Engine Thrust?
The discussion revolves around calculating the work done on a train powered by a jet engine thrust over a specified distance. The subject area includes concepts of physics related to work, force, and motion.
  • Exploratory, Assumption checking
  • The original poster attempts to apply the formula W=Fd to find the work done but encounters an issue with the answer. Other participants question the accuracy of the problem statement and the feedback received from the online server.
The discussion has revealed a potential misunderstanding or oversight regarding the calculation, as the original poster later acknowledges a mistake in their input. There is an ongoing exploration of the problem's details and the validity of the provided answer.
The original poster references using an online server for feedback, which may influence the interpretation of the problem and its solution.
missyjane
A train that had a mass of 18200 kg was powered across a level track by a jet engine that produced a thrust of 521000N for a distance of 444m. Find the work done on the train.
I thought this was pretty straightforward; however, it's apparently not.
I used W=Fd, but I got the wrong answer. Can anyone help me?
You should have gotten the right answer with that approach. Maybe the answer in your book is wrong.
It's through an online server (U Texas).
OK, then tell me:
1.) Did you post the exact problem statement?
2.) What answer did you get?
3.) What feedback did you get from the server?
Nevermind! I left off a zero! Thanks for your help though.
