Thread Closed
Is this ANSI C++?
Share Thread Thread Tools
Oct15-05, 02:40 PM   #1
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Is this ANSI C++?
Allow me to present a simplified version of what I'm doing: (yes, I have a reason to do this. )
Code:
class wrapper
private:
	int &v;
public:
	wrapper(int &value):v(value) {}
	wrapper& operator=(int value) {
		v = value;
		return *this;
	// This is the questionable bit:
	operator wrapper&() { return *this; }
wrapper make_wrapper(int &value)
	return wrapper(value);
template <typename T>
void foo(T &t)
	t = 1;
int main()
	int x;
	foo(make_wrapper(x));
To summarize:
I wish to create a class that acts as a reference type.
I would like to be able to pass my custom reference type into any template function that expects an actual reference.
But here's the problem: C++ doesn't let you make a non-constant reference to a temporary object.
Since it would be rather painful for me to overload every function I might ever want to call to take any combination of the reference types I'm writing, and for every function I develop to have multiple versions, I would like a more automatic approach.
Thus, I provided a conversion into (wrapper&). g++, at least, is happy with it.
Is this valid C++?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Oct15-05, 02:59 PM   #2
hmmm... well, if gcc has no issues with it then it must work ok. I know gcc is not yet perfect with respect to the ANSI standard, but oh well.
Oct15-05, 05:13 PM   #3
Code:
class wrapper
private:
int &v;
public:
v = value;
return *this;
void foo(T &t)
t = 1;
int main()
int x;
To summarize:
[/QUOTE]
i dont understand this, can you return an operator?(not that i know of) if you can the this pointer is a pointer to a class and not an operator.
maybe you mean
wrapper operator&(){ return *this; }
Oct15-05, 05:28 PM   #4
Recognitions:
Is this ANSI C++?
operator wrapper& is a conversion operator, like operator int, or operator char. It allows you to convert an object of type wrapper into an object of type wrapper&
Oct15-05, 05:32 PM   #5
Recognitions:
I'm mainly worried if the behavior is undefined, so that I can't expect it to work in general. =(
Oct15-05, 05:35 PM   #6
hmmm i havnt seen this before an cant seem to find anything in stroustrup's book have to got a link to an example or something please thanks.
Oct15-05, 05:37 PM   #7
edit.
hmmm now i see, sorry about that
Oct15-05, 08:55 PM   #8
dmail try looking under type casting...cuz thats what your basically doing
you can overload int and double's i believe...i use the typdef double REAL
and you can basically do (REAL*)vector...to get teh ntuple outta class vector.
so if you store an array in teh class
you can do operator REAL*() { return _a; } where _a is teh array. and thus you leave out the remainder of the class.
why do you need ansi standards hurkyl...can't you test it out on your compiler?
Oct16-05, 06:07 AM   #9
Recognitions:
Because it's nice to have code that relies only on defined behavior. This isn't solely for personal use -- I expect others to be able to use this as well.
Oct16-05, 08:29 AM   #10
Recognitions:
If you compile with gcc you can pass the -ansi parameter and it force the standard. You may also need to use the __STRICT_ANSI__ macro.
Oct16-05, 08:43 AM   #11
Recognitions:
Well, I suspect the syntax is valid, I'm more worried about the semantics -- whether I can be guaranteed that my object will live while I pass the reference around... -ansi doesn't guarantee me that, does it?
Oct16-05, 08:44 AM   #12
Recognitions:
Oh wait... I figured out how I can figure this out. I just need to make the destructor do something... gcc will surely put the destructor call exactly where it's supposed to go, right? Or is gcc allowed to wait for a more convenient time?
Oct26-05, 03:50 PM   #13
dpm
Code:
What exactly is this operator returning? It's currently untyped.
Other than that, returning *this is perfectly fine, IIRC. You just need to make sure that you don't access the memory after your object has been deleted.
Unless this is just for fun, check out the boost library. There's a few classes in there that do exactly this sort of thing, and you can look at the source to see how they did it, too.
Oct26-05, 06:13 PM   #14
Recognitions:
It's a conversion operator, syntactically no different than saying operator int(): it says that the compiler may use this operator to implicitly convert anything of type wrapper into one of type wrapper&.
Right, and my big question is when it gets deleted! I've since run my experiment, and it seems that the lifetime of the temporary is sufficiently long for my purposes (assuming that the compiler called the destructor at the earliest legal opportunity).
Which classes in particular?
Oct26-05, 10:44 PM   #15
Quote by Hurkyl
Destructors are called deterministically. When a stack-based object goes out of scope, its destructor is called immediately.
I think what you're doing is undefined behaviour. Your operator wrapper& is fine, but I don't think it's valid to return a reference to a temporary; I think that the temporary is created on the stack, and so any reference to it becomes invalid as soon as make_wrapper returns. I'm not sure, though. It's been a while since I had to think about the object creation rules in C++.
Oct29-05, 07:17 AM   #16
dpm
Quote by Hurkyl
Yes, I know that. I just got mixed up and thought that it should be explicitly stated that it is returning something. Apparently conversion operators don't have to have an explicitly stated return type.
http://www.boost.org/libs/smart_ptr/smart_ptr.htm
Thread Closed
Thread Tools
Similar Threads for: Is this ANSI C++?
Thread Forum Replies
Military Standards / ANSI / Mil Spec Mechanical Engineering 9
Lets talk all about ANSI C Programming & Comp Sci 6
