Can anyone explain Delegates in vb.net ?
  • Thread starter Thread starter Brad_1234
    Explain
Delegates in VB.NET are references to methods, functioning similarly to function pointers in C/C++. They enable runtime method invocation and are essential for event handling and callbacks in asynchronous programming. The discussion highlights the lack of clear explanations in existing examples, emphasizing the need for practical applications, such as invoking methods across different namespaces and classes. For effective usage, understanding the delegate constructor and variable instantiation is crucial.
  • Understanding of VB.NET syntax and structure
  • Familiarity with namespaces and classes in VB.NET
  • Knowledge of asynchronous programming concepts
  • Basic understanding of event handling in programming
  • Research "VB.NET delegate constructor" for detailed implementation
  • Explore "VB.NET asynchronous programming and callbacks" for practical examples
  • Investigate "VB.NET event handling" to understand delegate applications
  • Look up "VB.NET namespace usage" for accessing methods across classes
VB.NET developers, software engineers working with asynchronous programming, and anyone looking to deepen their understanding of delegates and event handling in VB.NET.
Brad_1234
In all the examples there is no explanation just code segments.
There is the delegate constructor and somewhere a variable is dimmed to the newly defined delegate type, then a second variable is dimmed, and it somehow works.
The variables most examples use have long names, the instantiated delegate sounds the same, the examples I find just don't explain the concept or how to use them.
Lets say there is a namespace with one class, and a method within that class that I want to call. from another namespace, different class, I want to run a method that can invoke a delegate and run the method in the first class
if there is a good explanation for vb.net delegates? Id appreciate hearing it
thanks
Technology news on Phys.org
The OP hasn't been around for about 10 years, but in case someone else has a similar question...
The short explanation is that a delegate is a reference to a method (in C/C++ parlance, a function pointer). The delegate concept is an advanced programming concept for which the main uses are being able to call a function at run time, as well is in responding to events. Delegates are also used in callbacks -- these are arguments in asynchronous methods where the callback is invoked when the asynchronous method has finished. This action let's the caller of the async function know that it has completed its task.
I'm not sure why you need a delegate for what you described. I haven't done any VB programming for a very long time, but the way it works in C# ought to be similar.
To use a method that belongs to a class in namespace NS, you would write a "using namespace NS;" statement in your program. If the class and its method are public, you would then have access to the class and its method. There would be a couple of ways to do this, depending on whether the class was defined as static or not.
For some examples, do a web search for "VB delegate examples" or "VB callback examples." That should get you some links to simple examples that you can play with.
  • · Replies 23 ·
  • · Replies 36 ·
  • · Replies 0 ·
  • · Replies 36 ·
15K
