Continuity of two-variable function
The discussion revolves around understanding the continuity of two-variable functions, specifically focusing on the function f(x,y) = √(x² + y²). Participants are exploring the implications of continuous projections and the continuity of polynomial functions in the context of two-variable functions.
  • Participants are attempting to understand why the continuity of projections implies the continuity of the function x² + y². Some are exploring the properties of polynomials and the sum of continuous functions. Others are questioning the rigorous mathematical background behind these assertions.
There is an ongoing exploration of the continuity of the function f(x,y) = √(x² + y²) at various points, with participants providing insights into limits and continuity in both Cartesian and polar coordinates. Some participants are suggesting that continuity in polar coordinates may simplify the analysis.
Participants are grappling with the definitions and conditions for continuity in two-variable functions, particularly in relation to limits and the behavior of functions as they approach specific points in their domain.
twoflower
Hi, I have some troubles understanding the basic facts about investigating the continuity of two-variable functions.
Our professor gave us very simple example to show us the basic facts:Very important is that projections are continuous, it means
[tex] \pi_1 :[x,y] \longmapsto x[/tex]
[tex] \pi_2 :[x,y] \longmapsto y[/tex]
are continuous.
Now let's have this function:
[tex] f(x,y) = \sqrt{x^2+y^2}[/tex]
It's continuous on the whole [itex]\mathbb{R}^2[/itex]. Why?
1. Step:
Projections are continuous
2. Step:
[tex] x,y \longmapsto x^2 + y^2[/tex]...continuous
3. Step:
Square root is continuous on [itex][0,\infty)[/itex]
What I don't fully understand is the second step. I can't see why, from the fact that projections are continuous, we can say that
[tex] x^2 + y^2[/tex]
is continous. Of course I didn't expect any other result, when you look at it it's obvious that it will be continuous, but I just can't see the rigorous mathematical background.
You know, I see it is some equivalent of the limit of product of single variable function (? is it the right expression ?), but I don't think it's sufficient. I would need some equivalent for two-variable functions...
Hope you understand my problem :)
Thank you very much.
I'll give it a try, but I'm not a mathematician, so I might get it wrong ; feel free to correct me if that's the case.
Consider the function [tex]a \rightarrow a^2[/tex]. That's a polynomial and hence continuous.
Now, consider the first function:
[tex](x,y) \rightarrow x \rightarrow x^2[/tex]
This is a projection, followed by our squaring, so that's a continuous function from (x,y) to x^2.
Next, consider the second function:
[tex](x,y) \rightarrow y \rightarrow y^2[/tex]
This is also a projection, followed by squaring, so that's a continuous function too, from (x,y) to y^2.
The sum of two continuous functions, is continuous, so if we add our two functions, we have [tex](x,y) \rightarrow x^2 + y^2[/tex]
should be continous.
Did I sneak in something ?
Twoflower,
Let the point [itex]M_0 (x_0,y_0)[/itex] belong to the domain of the function [itex]f(x,y)[/itex]. Then the function [itex]z=f(x,y)[/itex] is continuous at the point [itex]M_0 (x_0,y_0)[/itex] if we have
[tex]\lim_{\substack{x\rightarrow x_0\\y\rightarrow y_0}} f(x,y) = f(x_0,y_0)[/tex]
and (x,y) approaches [itex]M_0 (x_0,y_0)[/itex] in arbitary fashion all the while remaining in the domain of the function.
Now if [itex]x=x_0 + \Delta x , y = y_0 + \Delta y[/itex] then the above condition can be rewritten as
[tex]\lim_{\substack{\Delta{x}\rightarrow 0\\\Delta{y}\rightarrow 0}} f(x_0 + \Delta x,y_0 + \Delta y) = f(x_0,y_0)[/tex]
[tex]\lim_{\substack{\Delta{x}\rightarrow 0\\\Delta{y}\rightarrow 0}} [f(x_0 + \Delta x,y_0 + \Delta y) - f(x_0,y_0)] = 0[/tex]
or
[tex]\lim_{\substack{\Delta{x}\rightarrow 0\\\Delta{y}\rightarrow 0}} \Delta z = 0[/tex]
So for [tex]z=\sqrt{x^2+y^2}[/tex],
what is
[tex]\lim_{\substack{\Delta{x}\rightarrow 0\\\Delta{y}\rightarrow 0}} \Delta z[/tex] for any point in the domain?
siddharth said:
Twoflower,
or
what is
Doesn't get any easier than this.
It's very simliar, if not the same, as continuity for a single variable.
Actually, it does- put it in polar coordinates and it IS continuity for a single variable!
The point made earlier, by vanesch, is that you cannot be certain of getting the correct limit of
By simply taking [itex]\Delta y[/itex] going to zero and then taking [itex]\Delta x[/itex] going to 0. However, you can find the limit by seeing what happens when [itex](\Delta x, \Delta y)[/itex] is very close to (0,0). In polar coordinates that is measured by the single variable r. What do you get if you put this problem in polar coordinates?
  • · Replies 27 ·
  • · Replies 40 ·
