How to Calculate Molality for a 0.5% Urea Solution at 0°C?
  • Thread starter Thread starter shaiqbashir
    Molality
The discussion focuses on calculating the molality of a 0.5% urea solution at 0°C, where the molar mass of urea is specified as 60 g/mol. The osmotic pressure of the solution has been successfully calculated as 1.86 atm. To determine molality, the formula used is molality = number of moles of solute / mass of solvent in kilograms. However, the challenge arises due to the absence of the mass of the solute in the provided data.
  • Understanding of molality and its calculation
  • Knowledge of osmotic pressure and its formula
  • Familiarity with the concept of density in solutions
  • Basic skills in stoichiometry and molar mass calculations
  • Calculate the mass of urea in a 0.5% solution using the density of water
  • Learn about the relationship between molality and molarity
  • Explore the impact of temperature on osmotic pressure calculations
  • Study the properties of dilute solutions and their approximations
Chemistry students, researchers in physical chemistry, and anyone involved in solution chemistry or osmotic pressure calculations will benefit from this discussion.
shaiqbashir
Molality creating problems for me!
calculate the molality and osmotica pressur of a 0.5% solution of urea (Mol Mass=60) in water at 0 degree celsius.
R-0.0821
now my dear friends!
i have calculated successfuly the osmotic pressure in this question which is
osmotic pressure = 1.86 atm
now the problem is this that how to calculate this molality. i know that
molality = no of moles of the solute/ mass of the solvent in kilograms
but you see that here i don't have any masss of the solute given at all.
Please help me
Thanks in advance
Such diluted solution has density almost identical with the density of pure water.
17K
9K
10K
