Time as a Spatial Dimension: Is It Possible?
  • Context: Graduate
  • Thread starter Thread starter Funkee
    Dimension Time
The discussion revolves around the concept of time as a potential spatial dimension, exploring theoretical implications and interpretations within the context of physics. Participants engage with ideas related to the nature of time, its measurement, and its relationship to space, drawing on concepts from relativity and Kaluza-Klein theory.
  • One participant suggests that light originates from a 5th spatial dimension and proposes that time could be viewed as a spatial dimension, affecting how we perceive motion and change.
  • Another participant argues that time is a human invention and that only distance can be measured in a universal sense.
  • A participant notes that in relativity, space and time are treated similarly, with differences arising only in the sign of certain quantities in equations.
  • Some participants express skepticism about the feasibility of testing the idea of time as an extra spatial dimension.
  • Another viewpoint emphasizes that time should not be simply defined as the rate of change, suggesting a more complex relationship between time and spatial dimensions.
  • One participant discusses the implications of measuring distance in terms of time, referencing astronomical measurements like light-years.
  • Another participant proposes that mass (or gravity) could be considered the fourth dimension, influencing the perception and interaction of the other three dimensions.
Participants express a range of views, with no clear consensus on whether time can be considered a spatial dimension. Some agree on the equivalence of space and time in certain contexts, while others maintain distinct definitions and roles for each.
The discussion includes various assumptions about the nature of time and space, with some participants acknowledging limitations in their understanding of the mathematics involved. The exploration of these concepts remains largely theoretical and speculative.
Readers interested in theoretical physics, the philosophy of time, and the interplay between space and time may find this discussion engaging.
Funkee
I came up with an idea more than a year ago, but I've yet to take a physics course, still in high school, but please bear with me.
Take the Kaluza-Klein approach that light originates from the 5th spatial dimension, at the nearly unreachable Planck length. Now, light is supposedly a vibration that originates from there. If the light traveled parallel to our 4 dimensions of space-time, then we would never see it, confined to the 5th dimension. But it doesn't and crosses our dimensions.
That's where you can bring back the concept of absolute space and time. Since the entire universe may be moving at an immeasurable rate, because we all have mass, but it isn't measurable without some known constant, because everything in the universe is moving together at that speed in addition to any expansion or any other movement. But take the light beam. Since it crosses our dimensions from the 5th, all matter we know may be moving through the universe at a certain rate. But light isn't confined to our dimensions, moving through the 5th dimension as well, but it is not affected by the motion of the matter through space-time.
As best as I can illustrate it, imagine our space-time by a line, and the light beam crosses our dimensions from some other point. The point of intersection can be a reference for absolute motion, space or time.
Then suppose that time is a spatial dimension, that we are moving through. The reference point, to determine our velocity is the point of intersection of the light beam. Suppose that we are the ones that are traveling through space-time at 300,000 km/sec, away from the beam of light. Since we are moving through the universe together with everything else, except for light, we can just as well be moving from the light beam at the observed rate that it moves away from us.
Relativity says that as we move faster, time slows down for us. Now, time, as a "different" represents change as well as space. Now if we have a particle, and its velocity increases, the change that occurs is the particle begins to approach the point of intersection of the light beam and space-time. As it approaches the speed of light that we observe, which in this case is the speed that we are moving away from the light, its change in time decreases, and at the point that it reaches 300,000 km/sec, the velocity of light, time comes to a stop because the particle has ceased to change or move through time.
Take e=mc^2
If e is the total energy of the particle that encompasses the difference between c^2 and e, that gives the true mass to be 1/m, a hyperbolic function of absolute energy vs. mass. When the difference in energy approaches 0, then mass becomes infinite.
I can barely continue anymore because I can barely keep up with my thoughts. I'm as confused myself as many of you might be right now, so I'll get back to this in a little while. Again, I'm only 15 and have yet to take a formal course in physics, but any comments would be appreciated. I posted this a while back in the old forum with little replies. Hopefully I can get some more help this time around.
Time is not measurable in the universal sense because time is an invention of man. The only measurement of space that we can use is distance.
Well, in Relativity, space and time really are treated as exactly the same. The only difference is that one particular quantity is positive for temporal directions and negative for spatial directions, so when you actually plug numbers into the equations, the differences between space and time appear.
Hurkyl
Are you sure? May be on the contrary, indeed?
At first my sense of time was simply a measurement of change, but I had wondered as many had referred to time as a dimension itself, to try to apply it as another spatial dimension. I'm not satisfied by defining the 4th dimension of time as simply the rate of change.
The idea that time may be an extra spatial dimension has been around for a while. Intriguing, but it doesn't seem like an idea we'll ever be able to test.
I was speaking to a friend of mine today, regarding the idea. He said that approaching time as a spatial dimension isn't new, but the idea was mostly incorporated with space-time. I guess that's to a certain extent what I'm trying to say, but again, it's something different. It makes some sense to me, but I'm just a soph at high school, and haven't taken a formal physics course. I'm not too familiar with the mathematics of most physics so it wouldn't be up to me to test my own theory just yet. It's just an idea, thanks for the thoughts, though.
Since the space and time are equivalent, that it is correct to speak of not curvetion of space or its geometries, but about local change of the move of time. Herewith in the mass time goes quicker. The Atoms of different chemical elements have a different move of time. The Chemical reactions this averaging the move of time on two or several elements.
If asked the question - can time form the spatial dimension - I satisfy myself by saying that time is usually written as...10m/sec...10m^2/sec...10m^3/sec...in comparision to other dimensions...not 10m^3 sec/some other dimension...
But how you'll do perceive idea of measurement of the distance by means of Time only? Does it sounds strange? Though the Astronomy does not measure the distance by a metre or mile. It does measure by the Light Year. This is done as a matter of convenience simply, but has much greater sense indeed. Because
Distance = Time
I never meant to say that time cannot be equal to distant...all I wanted to say was that time may not be the 4th spatial dimension...
Hi, I know this is an old post, but just had to add my $.02.
DISCLAIMER (I AM NOT A PHYSICIST, I JUST LIKE THE TOPIC)
1. I couldn't agree more that the 4th dimension (time) is no different than the first 3, the only thing that is different is our perception of it.
2. I think the term "spacial dimensions" should be trashed. It implies that all of the first 3 dimensions are somehow "Full of space" or describe space, try to imagine having any space, with only 2 dimentions, or worse one. That's just silly.
4. the idea of dimensions being increadibly small or big is laughable. Dimensions are not measurable, they provide for measurement. I see no difference in the measure of time, or the measure of length. The only thing missing is a measure of timevolume. I can do it, easily, I just don't know what it would be useful for, because I don't PERCIEVE 4 dimensions very well. (at least not as well as I percieve 3) but the idea that something has more of some yet undefine unit of measure because it exist in a particular place for some particular time, is not hard to concieve.
my take on the matter is:
Mass(Gravity) is the fourth dimension. it has the ability to warp and distort the other 3 dimensions, we just can't perceive it on a small scale.
indeed its effects are pretty much absolute, such that even light is subject to its power. everything in the universe has a subsequent Mass(Gravity) "footprint" that affects its actions.
on a small scale we can ignore the effects, but on a vast scale we have to take it into account. suppose we were to make a 3D map of the universe and start filling it in with the locations of known stars etc.
suppose someone in a difference solar system at the same time starts doing the same thing.
his map will probably come out different from ours because the things he is using to deduce the object's location, be it (radar waves, light, gamma, whatever...) are coming to him from a different direction because its subject to different gravitational forces along that course.
if we take gravity into account when plotting, we can get a more accurate picture of where things really are.
An equivalence of space and time (t) can be realized using one dimension of space in term of distance (d) by the following simple equation.
[tex]d = ct[/tex]
where c is the speed of light in vacuum. This says that a time of one second is equivalent to a distance of 300,000 km.
If the one dimension of space possesses a local motion then space is also the same as time with two intrinsic directions of motion.
Time Dimension Distinguished from Spatial Dimension
This is where I stopped erading. Everything was fine until this. Either you switched a subject or something I'm confused.
Funkee said:
Take e=mc^2
If e is the total energy of the particle that encompasses the difference between c^2 and e, that gives the true mass to be 1/m, a hyperbolic function of absolute energy vs. mass. When the difference in energy approaches 0, then mass becomes infinite.[/QUOTE
When you say ..>"the true mass to be 1/m . . ." I wince. did you mwean to say the ". . . . inverse of the true mass to be 1/m, . . .?. Did you mean to write by dividing both sides of e = mc^2 by em, we get c^2/e = 1/m ? If you now say, the ratio of the speed of light to the energy is a hyperbolic function, this fits the math, then the words don't jibe with the math. So, writing the equation as v = (d/sec)^2 and d = distance and letting v = 1 unit speed of light (300,00x 1000), or v = 1, then your distance becomes d^2 = sec^2 or d = sec, or some time unit say kt. The k we can use to encompass all of our unit value asssumptions. The important thing here is you've got d to be expressed as a function of t, or d = kf(t), which would make 'k' a lot more than just a conveneient constant.. I'm simple minded. When someone askes me how far is LA from here, I say, "about 31/2 hours", if someone asks me how far is the nearest Fast Trip is, I say, "a couple of blocks". Now, if you ask about the Clauser experiments you get a feeling for an expanded version of time.
If two photons are emitted at the same time from a source where the photons are traveling in opposite directions with a total angular momentum = to zero, then to maintain the conservation of angular momentum if one photon has an angular momentum of +1 we can assure ourselves the other photon must have an angular momentum of -1. Now we assume the angular momentum vector in the photons is randomly and wildly changing. We let the photons get a 4 light years from each other and then measure one component of angular momentum oinone of the photons and say we get +1/3. The angular momentum detector we placed 10 light years in the other direction then measures after 8 more years, the same angular moment component of the twin and we get -1/3. If we had measured the second twin a micro second after measuring the first we still get -1/3. Question: did a signal go from one photon to the other setting the other angular momentum to -1/3? If it did the signal didn't go through space, which would violate he current understanding of relativity. For our purposes, the effect was instantaneous. There was a connection between the photons to be sure, but it certainly was not a spatial connection. Some call the connection a "quantum entanglement" which is descriptive enough. I like to refer to the connection as a nonlocal force exchange. We look all over the place and find no observed force or forces that can explain the connection. So. we can refer to the condition or scenario as an expression of nonlocal variables, or hidden variable. JS Bell tells us rightfully, that quantum theory cannot be expressed properly as "hidden local variables", but demands a structure of "hidden nonlocal vaiables". Remove the word hidden as all is expressed in "nonlocal". The entanglement expression that some use means to me the two photons were sharing some nonlocal function that, had they not been twins, they would have this nonlocal function for their very own. In any event we see action at a distance that works on a timing scheme.
The measuring of one component effectively stopped the timing function/counter wherever, or however it was functioning in that photon. The same signal was felt by the twin yonder, right now. I see a button, "stop moving the angular momentum vector when pushed". The force exchange channel, or nonlocal force exchange function seems confined to time functions only and is impervious to spatial significance. Pushing the button in one stops both motions instantaneously, where instantaneously gives a pure non-spatial characteristic of it all.
There is the curious aspect that you described to in the time 'dimension' crossing the one we all see, if I read you correctly. The measurement was a purely observed or local force exhange, otherwise we don't measure the angular momentum. If the nonlocal force exchange channel is purely nonlocal there seems to be a contradiction. However, if the nonlocal aspect of reality is universal, this means the contradiction of pure nonspatial or nonlocal is in a constant state of exchange with the local and this would be an essential characterisitc of the observed reality. I suppose you could call it what one hand clapping really is all about.
You did prove one thing to me however, that there is more than one intuitve investigator of nature.
Good paper.
  • · Replies 17 ·
  • · Replies 0 ·
