Find initial velocity using energy
The discussion revolves around a physics problem involving a 1.4 kg box sliding across a floor with a coefficient of kinetic friction of 0.3. Participants are exploring the calculation of the box's initial velocity using energy principles and the work-energy theorem, while also considering the effects of friction.
  • Mixed
  • Participants discuss the calculation of frictional force and energy loss due to friction. Some explore using the work-energy principle, while others suggest alternative methods involving acceleration derived from the coefficient of friction. Questions arise regarding the accuracy of significant figures in the calculations.
The discussion is active, with multiple participants providing different approaches and calculations. There is a focus on ensuring accuracy in significant figures, and some participants express uncertainty about the methods used. No consensus has been reached on the best approach or the correctness of the initial calculations.
Participants note the importance of significant figures based on the given data, highlighting potential discrepancies in the calculations due to this factor. The original poster seeks clarification on the energy method, indicating a desire for deeper understanding rather than just a solution.
physics333
A 1.4 kg box slides 15m across the floor. The coefficient of kinetic friction between the box and the floor is 0.3. I found that friction force in slowing the box was -61.74J. Is this right?
What was the initial velocity of the box?
I worked this problem using Kf = Ki + Wnc and found that Vo =9.4m/s. Is this right? Also I would like to know how to work this problem another way with Energy. Any help with what formula to use or any help at all will be great.
Would anyone else like to take a guess?
Well, this isn't an energy method but
μk=0.3 means that a=0.3g or about 2.94m/s2 so you could use that to get an answer. (9.39 m/s)
force of friction = (0.3)(1.4)(9.8)
force of friction = 4.116N
energy lost to friction = Fd
energy loss to friction = (4.116)(15)
energy loss to friction = 61.74J
E = (1/2)mv^2
v^2 = 2E/m
v = sqrt(2E/m)
v = sqrt(2(61.74)/(1.4))
v = 9.39m/s
all work shown and it agrees with the previous guy's answer
You lose points for and incorrect number of significant digits.
Correct answer 62J
Likewise other responders there is at most 2 good digits in the given information, you cannot give more then that in the answer. A nit picky detail but one you need to be aware of. The common use of calcultors for the most trivial of computations makes this sort of error very common.
Correct answer 62J
If you're going to nitpick, do so correctly. The coefficient of kinetic friction has only one significant digit.
If you are an engineer, you either have the number of digits the question gave or use 3; whichever is greater. If the number starts with a 1, you use at least 4. Angles are to be expressed to at least 2 decimal places.
Obviously I am not an engineer.
You know I looked right past that single digit in μ
Ouch!
- Warren
