Solve Binomial Expansion: (2/x^2-x)^6 - No x Term
  • Thread starter Thread starter zbobet2012
    Binomial Expansion
The discussion revolves around finding a specific term in the binomial expansion of the expression (2/x^2 - x)^6 that does not contain the variable x. Participants are exploring the properties of binomial expansion and how to identify terms based on their powers.
  • Participants are discussing the application of the binomial theorem and the conditions under which terms will cancel out the variable x. There are attempts to derive relationships between the powers of the terms involved.
The discussion is ongoing, with some participants providing insights into the structure of the binomial expansion and how to identify terms that yield no x. There is a mix of interpretations and attempts to clarify the reasoning behind certain expressions, but no consensus has been reached yet.
Some participants express a need for further clarification on the binomial expansion process and its application to this specific problem, indicating a potential gap in foundational understanding. There are also references to constraints related to homework expectations and the need for step-by-step guidance.
zbobet2012
I understand how Binomial expansion works, but I don't understand how to solve this problem.
Give the term of (2/x^2-x)^6 that has no x.
I take it you mean: [tex](\frac{2}{X^2}-X)^6[/tex]. In this case we simply want to solve 2A=6-A for the term where (-X)^(6-A) and X^2 is raised to the term A. Obviously, A=2, giving: [tex]\frac{6!}{4!2!}2^2[/tex]
If a = 2/x^2 and b = -x then the expansion will contain various products of powers of a and b. Some of those products will be such that the x's cancel. Can you see which ones? Can you calculate their coefficients using the Binomial theorem?
Where did this: 2A=6-A
Come from?
Robert means that each term in the series will be of degree 6, i.e. the combined powers of a and b (from my earlier post) add up to 6. For one or more of those terms the power of x will be zero.
I know its asking a lot, but can you show a step by step on how to solve it? I was out of class for a few days and never got taught how... Thanks a lot.
You said you understood how the binomial expansion works so you can easily do it yourself.
Expand [itex](a + b)^6[/itex] using the binomial expansion. As a shortcut, you can use Pascal's Triangle to find the binomial coefficients. When you're done with that, replace a with [itex]2/x^6[/itex] and b with [itex]-x[/itex]. Your answer should then leap off the page!
Good luck.
Thanks a lot tide, that helps a lot. I also think I found a generalized method for finding the [tex]x^n[/tex] term.
If we have [tex](\frac{C}{X^k}-X^m)^z[/tex] than [tex]x^n[/tex] can be found where [tex](-x)^{z-a}[/tex] where [tex]ka=z-ma+n[/tex]
  • · Replies 18 ·
  • · Replies 19 ·
  • · Replies 24 ·
