Installing Ubuntu on Phillips CD-ROM: Can I Use an External Drive?
  • Thread starter Thread starter sid_galt
    Drive Ubuntu
The discussion focuses on installing Ubuntu on a computer with an incompatible Phillips CD-ROM. Users explored the possibility of using an external CD drive, but the computer does not support booting from it. Alternative methods, such as installing directly from the hard drive, were attempted but resulted in a GRUB prompt. Suggested commands to resolve the issue include "root (hd0,1)", "setup (hd0)", and "quit" before rebooting.
  • Understanding of GRUB bootloader commands
  • Familiarity with Ubuntu installation processes
  • Knowledge of partitioning in Linux
  • Basic troubleshooting skills for boot issues
  • Research "GRUB command line usage" for troubleshooting boot issues
  • Learn about "Ubuntu installation from USB drives" as an alternative
  • Explore "Partitioning with GParted" for better hard drive management
  • Investigate "Boot repair tools for Ubuntu" to fix boot problems
This discussion is beneficial for users attempting to install Ubuntu on systems with incompatible hardware, particularly those facing boot issues and looking for alternative installation methods.
sid_galt
I tried installing Ubuntu on my computer. Turns out that the CD-ROM is not compatible with it (it's phillips). Can I install it from an external CD drive (my computer does not boot from external CD Drives)? If so, how?
I don't have a floppy drive so I can't use boot floppies.
I also contemplated installing straight from the harddrive as documented https://wiki.ubuntu.com/Installation/FromWindows" .
However this isn't working either as on boot, it just shows me the
Code:
grub>
prompt.
Does anyone have any ideas?
Computer science news on Phys.org
Try entering these commands at the grub> command line and see if it helps
Code:
 root (hd0,1)
 setup (hd0)
 quit
Then you can reboot with ctrl-alt-del
  • · Replies 18 ·
