Help Solve Puzzle: (n!)^3 n = {1-99}
  • Context: Undergrad
  • Thread starter Thread starter PrudensOptimus
    Puzzle
The discussion revolves around the problem of determining the number of digits in the sum of the cubes of factorials from 1 to 99, specifically expressed as (1!)^3 + (2!)^3 + ... + (99!)^3. Participants explore various approaches to solve this problem, including mathematical tricks and properties of logarithms.
  • One participant initially attempts to sum the cubes of factorials and proposes a formula involving a summation, but receives feedback that their approach is incorrect.
  • Another participant clarifies that the problem is about the sum of the cubes of factorials rather than a single expression.
  • Some participants suggest that (99!)^3 dominates the sum, and propose using logarithmic properties to determine the number of digits in (99!)^3.
  • There is a discussion about the formula for calculating the number of digits, with one participant noting the importance of the floor function in the computation.
  • Another participant questions the validity of the initial summation approach and points out that there are terms in the middle that may contribute additional digits.
  • There is a debate about the correctness of a specific mathematical identity related to summation, with participants discussing the implications of using factorials versus simple integers.
Participants do not reach a consensus on the correct approach to the problem. There are multiple competing views regarding the validity of the initial summation method and the implications of the logarithmic calculations.
Some participants express uncertainty about the mathematical steps involved, particularly regarding the summation of factorials and the application of logarithmic properties. The discussion reflects a range of assumptions and interpretations of the problem.
PrudensOptimus
Problem:
[tex](n!)^3[/tex] n = {1-99}
How many digit is the resulting [tex](n!)^3[/tex]?
Attempted solution:
[tex]\Sigma^{99}_{n=1} (n!)^3 = (\Sigma^{99}_{n=1} (n!))^3 = 99(\frac{1!^3 - 99!^3}{2}) =~ 470[/tex] digits. But they say it's wrong. Please help.
Mathematics news on Phys.org
None of this post made sense... try it again from scratch?
The problem is:
(1)!^3 + (2)!^3 + ... + (99)!^3
How many digits are in the resulting sum?
Ah, ok, I wasn't sure.
Anyways, I think it's a trick question. :smile: (99!)^3 is a lot bigger than the rest of the terms in the sequence.
The formula to compute the number of digits d the number n has is:
[tex] d = \floor{\log_{10} n} + 1[/tex]
And you can use the properties of logarithms to evaluate this when [tex]\mbox{n=(99!)^3}[/tex].
Once you know how many digits there are in (99!)^3, figure out the maximum possible number of digits in the sum of the rest of them and see if you can prove that the number of digits in (99!)^3 is or is not the number of digits in the sum.
Hint: For this second part, it may be simpler to first try and solve this brain teaser:
What is the largest 6 digit number that has the property that if you add a 3 digit number to it, the sum still has 6 digits?
Hurkl, where did you learn all these "mathematic tricks"? They are very valuable, more like "mathematical treasures!"
after solving d, the answer came very close to my answer... 469.
Bah, the floor function didn't appear in my TeX.
You're supposed to round down in this computation, sorry, so it's 468.
Basically, I've done a lot of math. :smile: (It's been a hobby ever since I was like 2) The more math you read and do, the more tricks, facts, et cetera you pick up.
So was there something wrong with my sigma approach? Rounding?
Originally posted by PrudensOptimus
[tex]\Sigma^{99}_{n=1} (n!)^3 = (\Sigma^{99}_{n=1} (n!))^3[/tex]
Is a pretty huge increase.
There are a bunch of terms in the middle that you skipped which might account for the extra digits.
The next step doesn't follow either; it is not true that [tex]\mbox{(\Sigma^{99}_{n=1} (n!))^3 = 99(\frac{1!^3 - 99!^3}{2})}[/tex]
Isn't it true that:
[tex]\Sigma^N_{n=1} n_N = N(\frac{n_1 + n_N}{2})[/tex] ?
Isn't it true that:
Yeah, but you're dealing with n!, not n.
\Sigma^N_{n=1} n_N
What do you mean by [tex]\mbox{n_N}[/tex]?
  • · Replies 16 ·
