How Long Does It Take a Bullet to Traverse a Wall with Variable Resistance?
  • Thread starter Thread starter vabamyyr
    Bullet Dynamics
The discussion focuses on calculating the time it takes for a bullet to traverse a wall of thickness h, given its initial speed v1 and final speed v2. The force acting on the bullet is proportional to the square of its velocity, represented as F = -kv^2, where k is a constant. The derived equation for time, t = (v1-v2)/(v1*v2)*(m/k), requires the relationship between mass m and the constant k to be established through the wall's thickness h. The acceleration is expressed as a function of position, leading to a differential equation that helps in determining the unknown ratio k/m.
  • Newton's Second Law of Motion
  • Differential Equations
  • Basic Kinematics
  • Understanding of Forces and Motion
  • Study the application of Newton's Second Law in variable force scenarios.
  • Learn how to solve first-order differential equations.
  • Explore the relationship between force, mass, and acceleration in motion through a medium.
  • Investigate the effects of drag forces on projectile motion.
Physics students, engineers, and anyone interested in the dynamics of projectiles and the effects of resistance in motion through materials.
vabamyyr
bullet enters a wall with speed v1 and goes out with speed v2, the wall is h units thick. During that time it experiences an impending force which is proprtional to v^2. I have to find the time the bullet goes out the wall.
I can take t0=0 v0=v1 x0=0
Using N2 law i get d(mv)/dt = -F.....mdv/dt = -m*v^2 (im not sure if I am missing here something)
dv/dt = -v^2
dt = - dv/v^2 ===> t = (v1-v2)/v1*v2...this result is weird since it doesn't contain h so i must have constructed the equation wrongly i guess.
I think that F depends on h since F can act only between [0; h], and maybe the answer should be multiplied with h and t = h*(v1-v2)/v1*v2...but it still doesn't look right to me...any opinions?
Well, the force was said to be proportional to v^2.
So F= -kv^2, where k is a constant
and dv/dt=-k/m* V^2
[Quote}
dv/dt = -v^2
dt = - dv/v^2 ===> t = (v1-v2)/v1*v2...this result is weird ...[/QUOTE]
Including that constant k and m the mass of the bullet, you get
t=(v1-v2)/(v1*v2)*m/k (A)
But you do not know m/k. You should get it from h, the distance travelled.
You are on the right track. F depends on the position of the bullet inside the wall through the velocity. So the acceleration canbe considered as function of the position, x.
a = dv/dt = dv/dx * dx/dt = dv/dx *v.
F= ma = - kv^2
m*dv/dx *v = - k*v^2,
or dv/dx = (-k/m)*v
Solve this differential equation with the condition that v=v1 at x=0 and v=v2 at x=h. You get an expression containing the unknown k/m which you can use to determine t from equation (A).
ehild
thanks, i liked ur comments and u have been most helpful
  • · Replies 27 ·
  • · Replies 26 ·
