How Do You Determine Reactivity in Double Displacement Reactions?
  • Thread starter Thread starter extraordinarygirl
The discussion revolves around understanding double displacement reactions, specifically how to determine the reactivity of metals involved in these reactions. Participants explore concepts related to displacement, reactivity series, and the conditions under which reactions occur, including the formation of precipitates or gases.
  • Homework-related
  • One participant expresses confusion about whether to assess the reactivity of the first or second metal in a double displacement reaction.
  • Another participant suggests that the question may actually pertain to single replacement reactions, where a more reactive metal displaces a less reactive one, referencing an activity series of metals.
  • A detailed activity series is provided, listing metals from lithium to gold, indicating their reactivity levels.
  • Examples of reactions are given to illustrate how the reactivity series determines whether a reaction will occur, including a specific example involving copper and silver nitrate.
  • Clarification is provided that double displacement reactions involve two ionic substances in solution and can result in the formation of a precipitate or gas.
Participants do not reach a consensus on the initial question regarding double displacement reactions, as one participant interprets it as a single replacement reaction. There are multiple viewpoints on how to approach the topic, indicating that the discussion remains unresolved.
The discussion includes references to the reactivity series and specific examples of reactions, but it does not clarify the definitions of double versus single displacement reactions in detail. There is also a lack of consensus on the interpretation of the original question.
extraordinarygirl
I am having trouble with double displacement reactions. I know for some of them, no reactions will occur because the metal isn't strong enough to displace the other metal . I was wondering if any of you could clear this up.
Do I see if the first metal can displace the second metal, or do i see if the second metal can displace the first?
--If you could answer me quickly, that would be awesome. :smile:
Can someone please help me I have a test on this tomorrow!
I am guessing what you are talking about is actually a single replacement reaction where one more reactivite metal displaces another metal in solution.
The activity series is as follows:
Lithium
Potassium
Barium
Calcium
Sodium
Magnesium
Aluminum
Manganese
Zinc
Chromium
Iron
Cobalt
Nickel
Tin
Lead
Hydrogen (acids)
Copper
Silver
Mercury
Platinum
Gold
For example consider the reaction between copper and silver nitrate.
Cu + 2AgNO3 --> Cu(NO3)2 + 2Ag
This reaction occurs because copper is more reactive than the silver which is in solution as silver nitrate. The converse of that equation would not occur:
Ag + Cu(NO3)2
because silver is less reactive than copper.
Anything above hydrogen on the reactivity scale will react with an acid. For example: zinc and hydrochloric acid
Zn + 2HCl --> ZnCl2 + H2
So basically look at the bare metal and see if it is higher up on the chart than the metal in the compound. If it is, then the reaciton will occur.
A double displacement reaction deals with two ionic substances in solution and will occur with the formation of a precipitate or a gas.
For example:
Na2CO3 + CaCl2 --> 2NaCl + CaCO3(s)
This reaction occurs because CaCO3 (calcium carbonate) is insoluble.
Na2CO3 + 2HCl --> 2NaCl + H2CO3
Carbonic acid is unstable: H2CO3 --> H2O + CO2(g)
This reaction occurs because CO2 gas is formed.
Thank you so much
  • · Replies 28 ·
