Register to reply
Plasma balls- Dangerous at all?
by matthyaouw
Tags: balls, dangerous, plasma
Share this thread:
matthyaouw
#1
Oct18-05, 05:08 PM
PF Gold
matthyaouw's Avatar
P: 1,216
I've recently found my old plasma ball, so decided to waste a couple of hours becoming entranced with it. I noticed that if I touched it with anything other than my hand, the streams didn't seem to be attracted to it. I did a bit of reading on it and found that it has to be something which will conduct electricity quite well, so I try a few things to no avail, and decide it's tinfoil time. This works quite well, but then I discover that if I balance it on top of the ball and hold my finger near it, I can make some tiny sparks from the foil to my finger. This amuses me for a little while, until I start to smell a rather strong burning smell coming from my finger. I'm a little reluctant to continue now. Is there any danger in doing this, or is it pretty safe?
Phys.Org News Partner Physics news on Phys.org
First in-situ images of void collapse in explosives
The first supercomputer simulations of 'spin?orbit' forces between neutrons and protons in an atomic nucleus
Magnets for fusion energy: A revolutionary manufacturing method developed
nbo10
#2
Oct18-05, 05:12 PM
P: 415
Was your finger burning? If it was, you might not do that anymore. If it wasn't, keep going.
matthyaouw
#3
Oct18-05, 05:15 PM
PF Gold
matthyaouw's Avatar
P: 1,216
Not in the "on fire" sense, but it smells like it has been. There was no pain by the way. A slight tingle, but that is all.
berkeman
#4
Oct18-05, 06:16 PM
Mentor
berkeman's Avatar
P: 40,658
Quote Quote by matthyaouw
You might just be smelling ozone from the ionization discharge that you saw between the foil and your finger. Try holding a sharp metal object with your hand and arcing the tip of the metal edge to the foil. If you smell the same smell, it's ozone (or some other byproduct of the ionization discharge -- I don't know offhand if ozone is odorless).
Mk
#5
Oct19-05, 12:55 AM
P: 2,056
An easier way is to put a CD you don't want, or an unburned one into your microwave oven for ~2 seconds. Open the door and smell what's in there. That is the smell of ozone, O3
The two pictures below show what happens when you touch the bulb. Notice the *HOT* plasma channel moving upwards to my hand, which is right above the bulb. The maximum I could touch the bulb for was about 10 seconds, after that it would become hot enough to really burn my skin! The plasma stream is so dense, in fact, that by touching the bulb with a grounded wire, you can actually melt through the glass in a few seconds! A real plasma torch!
Here's also an mpeg from the site: http://powerlabs.org/movies/burnglass.mpg You can see the stream of plasma make its way out of the globe and to the metal rod! Which a person is holding!
matthyaouw
#6
Oct19-05, 04:05 AM
PF Gold
matthyaouw's Avatar
P: 1,216
I tried using foil and another metal object. Lots of sparks, but no smell this time, so I reckon it must have been me I smelled. I guess that's a sign to stop.
That video is pretty cool. I wonder if it's the same as I'm doing but with higher voltages. I don't think mine can melt through the glass though (or at least I hope not)
nbo10
#7
Oct19-05, 10:22 AM
P: 415
electrical burns can damage muscle below the skin without harming the skin. Like the old saying goes, it's not the injury that kills ya, its the infection.
DaTario
#8
Oct19-05, 10:43 AM
P: 555
I have one of these plasma balls and this small discharges simply seems to burn part of our skin, producing the smell you have mentioned. No harm seems to be involved as long as you do it few times a week, just to present the effect to others. Carbon compounds, organic compounds, when burned, may originate cancer inducing substances. This is the principal reason to avoid doing this experiment frequently.
Try rotating gently the plasma ball and you will find out that there is really a gas inside, for its viscosity makes the streams rotate also.
I wonder if experiments with isopor balls may result in situations where they stay floating near de ball due to electrization process.
Best Regards,
DaTario
Register to reply
Related Discussions
Red Balls, Green Balls and Expectations Set Theory, Logic, Probability, Statistics 2
I'm about to do something dangerous General Discussion 91
Why is HF dangerous Chemistry 6
Is this too dangerous? General Discussion 0
