| Thread Closed |
my paper on the Born rule... |
Share Thread | Thread Tools |
| Mar3-06, 01:46 AM | #137 |
my paper on the Born rule...However, the number of eigenspaces of the measurement operator is purely determined by the measurement apparatus. It is given by the resolution by which we could, in principle, determine the quantity we're trying to measure, using the apparatus in question. You and I agree that this must be a finite number, and a rather well-determined one. This is probably where we are differing in opinion, and where you seem to claim "micromeasurements" of eventually unknown physics of which we are not aware versus "macromeasurements" which are just our own coarse-graining of these micromeasurements- while I claim that with every specific measurement goes a certain, well-defined number of outcomes (which could eventually be more fine-grained than the observed result but that this should not be dependent on "unknown physics", but that a detailled analysis of the measurement setup should reveil that to us). I would even claim that a good measurement apparatus makes the observed number of outcomes about equal to the real number of eigenspaces. Also, you now have a strange outcome! You ALWAYS find probability E_i for outcome i, no matter what was the quantum state ! Even if the quantum state is entirely within the E_i eigenspace, you'd still have a fractional probability ? That would violate the rule that two measurements applied one after the other will give the same result. What I meant with "at first sight" is that one doesn't realise the magnitude of the step taken! In unitary QM, there IS no notion of probability. There is just a state vector, evolving deterministically by a given differential equation of first order, in a hilbert space. From the moment that you require, no matter how little, a certain quality of a probability issued from that vector, you are in fact implicitly postulating an entire construction: namely that probabilities ARE going to be generated from this state vector (probabilities for what, for whom?), that only part of the state vector is going to be observed (by whom?) etc... So the mere statement of a simple property of the probabilities postulates in fact an entire machinery - which is not obvious at first sight. Now if your aim is to DEDUCE the appearance of probabilities from the unitary machinery, then implicitly postulating this machinery is NOT reasonable, because it implies that you are postulating what you were trying to deduce in one way or another. cheers, Patrick. |
| Mar3-06, 07:11 AM | #138 |
| Mar3-06, 07:15 AM | #139 |
| Mar3-06, 07:20 AM | #140 |
It takes a singular mind to come up with such things! (Okay, I'll stop now)
| Mar4-06, 04:33 AM | #141 |
5 or so years ago when I was visiting Paul Kwiat you gave me a preprint of how you thought the Born rule could/should be derived. I remember there was a cute idea in there somewhere, though I can't remember what it was! How did it pan out? Tez |
| Mar4-06, 09:14 PM | #142 |
This view is consistent with the notion that it does not matter whether there is data reduction up to the display. That is, it does not matter whether the CCD has resolution of 1 mm or 1 cm; if two different CCD's have different pixel resolution, but are made of the same types of atoms, then they will have the same fundamental fine-grained "resolution" when we look at the micro-structure. I'm starting to contemplate a thought experiment, not sure where it will take me. Suppose we have a CCD camera (length, say, 10 cm) and we remove a 2 cm chunk of it which we replace with a lens that focuses all particles that would have hit the plate on that 2 cm stretch onto (for the sake of argument) a single atom. What effect do we expect this will have on our measurement probabilities? Contrast that to a different scenario: we have a CCD camera, length 10 cm, with resolution 1 mm. Remove a 2 cm chunk and replace it with a single pixel, ie 2 cm resolution. But both CCD setups are made of the same types of atoms. I would expect that the probability of detection over the 2 cm single pixel equals the sum of the probability of detection of all 20 of the individual 1 mm pixels; my reasoning is that in both setups, we have the same density and type of atoms in the CCD's. But I would imagine that using the lens setup, we would get something completely different, since we are effectively replacing detection over a 2 cm stretch using lots of atoms with detection using only one atom. |
| Mar4-06, 09:25 PM | #143 |
| Mar5-06, 08:03 AM | #144 |
Doesn't your spatial-resolution fiddling bear a family resemblance to Asfhar's analysis? I believe that was described here recently in Quantum Zeno terms.
| Mar5-06, 03:45 PM | #145 |
As for the Zeno effect, I have actually not really pondered it really really deeply. But from my cursory contemplation, the existence of the Zeno effect does not surprise me all that much. To me, the main lesson of the Zeno effect could be stated loosely: how you measure something (the resolution of the time measurements) has an effect on the probability distribution (probability of decay as a function of time). But that is simply Lesson # 1 (in my mind) in quantum mechanics. eg, the 2-slit exp tells us that how we measure something (whether we do or do not look at the slits) has an effect on the resulting probability distribution (where it hits the screen). So perhaps the Zeno effect is just teaching us the same lesson as the 2-slit exp, but dressed up differently. So my knee jerk reaction to your question would be that Afshar's analysis is based in a (somehow) flawed reading/implementation of the CI (and MWI), but the Zeno effect is founded upon a correct implementation of quantum theory. I'd have to take another look at Afshar though to see the comparison with Zeno ... David [1] Styer et al. Nine formulations of quantum mechanics. Am J Phys 70:288-297, 2002 |
| Mar5-06, 03:57 PM | #146 |
D http://en.wikipedia.org/wiki/Afshar_experiment |
| Mar5-06, 04:56 PM | #147 |
wow I just the wiki article on the ashfar experiment... mmm.. so proc. spie is an optical engineering journal and not a physics journal...
I guess it must be generally believed by the physics powers that be that ashfar's interpretation of the experiment is erroneous. good enough for me i guess.. hehe |
| Mar5-06, 05:13 PM | #148 |
That's right, I beat him to the punch ... who's ya' daddy now??? DS <ducking in case Lubos is lurking about somewhere ...> [1] http://motls.blogspot.com/2004/11/vi...mentarity.html [2] http://groups.yahoo.com/group/undern...s/message/1231 |
| Mar6-06, 01:47 AM | #149 |
Afshar's experiment has been discussed here before also:
http://www.physicsforums.com/showthread.php?t=59795 |
| Apr12-06, 04:00 PM | #150 |
Hi Tez- Sorry for the delay- haven't been checking the forum. The idea was that if there were a non-linear decoherence process, the proper ratio of world-counts could arise asymptotically without fine-tuning. Basically it runs like this: if large-measure branches decohere faster than small-measure ones the limiting steady-state distributions would have the same average measure per branch. Hence branch count is simply proportional to measure. How'd it work out? It was published in Found Phys. Lett., after some extraordinary constructive criticism from a referee. So far there are no obvious holes in it- e.g. no problem with superluminal communication, unlike some types of non-linear dynamics. On the other hand, it proposes extra machinery not in ordinary quantum mechanics, without giving a specific theory. Although the extra gunk is much less Rube-Goldbergish than in explicity collapse theories, it would be nice not to have to propose something like that at all. I'm about to post a follow-on, in which I point out that once the non-linear processes have been proposed to rescue quantum measurement, they give the second law at no extra cost. A similar point was made by Albert in his book Time and Chance, but he was referring to non-linear collapse (much uglier) rather than simple non-linear decoherence. |
| Apr29-06, 07:54 AM | #151 |
Hey everyone,
I ran across this recent paper [1] (it was posted to Vic Stenger's list) that is relevant to the issues of this thread. "Egalitarianism" (= the APP) is discussed, and Huw seems to agree with Wallace and Greaves that Egalitarianism is "not ... a serious possibility." However, in a footnote he makes a distinction between "branch-Egalitarianism" and "outcome-Egalitarianism," and states that it is only the former that is not a possibility, whereas the latter "does seem to remain in play -- an alternative decision policy whose exclusion needs to be justified ..." I'm not sure I understand his distinction between branch and outcome Egalitarianism, though -- if anyone can explain it to me, I'd be interested! Huw also describes a very interesting problem called the "Sleeping Beauty problem" which I had never heard of before. It raises a very interesting conceptual method for ascribing a "weighting" to each branch. I won't recap it here, since he does a good job of it in the paper. David [1] Huw Price. "Probability in the Everett World: Comments on Wallace and Greaves." 26 Apr 2006 http://arxiv.org/PS_cache/quant-ph/pdf/0604/0604191.pdf Abstract: |
| Thread Closed |
| Thread Tools | |
Similar Threads for: my paper on the Born rule...
| Derivation of the Born rule | General Physics | 6 | ||
| Would Bohr be born if Bohm were born before Born? | Quantum Physics | 10 | ||
| Attempts to make the Born rule "emerge" explicitly from outcome counting | Quantum Physics | 4 | ||
| Arnold "born to rule" Europe? | Current Events | 25 | ||
