Heating a dark non-reflective body in space
  • Context: Undergrad
  • Thread starter Thread starter -Job-
    Body Heating Space
The discussion revolves around the behavior of a dark, non-reflective body in space when subjected to radiation. Participants explore concepts related to heating, cooling, energy conservation, and the implications of radiation absorption and emission. The scope includes theoretical considerations and some experimental references.
  • One participant questions why a dark, non-reflective body would cool down after being heated by radiation, pondering the implications for energy conservation.
  • Another suggests that the heat absorbed will be re-radiated as infrared radiation, eventually reaching thermal equilibrium with the ambient temperature.
  • A participant raises the idea of whether a dark body can still be detected through its radiation emissions and questions the effects of motion on radiation emission.
  • Concerns are expressed about the definition of a "dark" body once it has been heated, with a suggestion that it may no longer fit that definition.
  • One participant explains that mechanical pushes on the body would generate heat through various means, complicating the scenario of purely radiative heating.
  • Another participant discusses the momentum transfer from radiation, noting that a reflective surface would yield different results compared to an absorbing one.
  • A reference is made to the Crooke's radiometer, illustrating how absorbed light can cause motion through heating the air, rather than direct momentum transfer from photons.
  • One participant emphasizes that an object in space will reach a temperature based on its absorption and emission characteristics, and describes how it would return to equilibrium with its environment after heating.
  • There is a clarification regarding the operation of radiometers, noting that they do not require a perfect vacuum to function.
Participants express various viewpoints on the behavior of the dark body when heated and the implications for energy conservation. There is no consensus on the specifics of how the body interacts with radiation or the definitions of "dark" in this context, indicating ongoing debate and exploration of the topic.
Some assumptions about the environment and definitions of terms like "dark" and "non-reflective" remain unresolved. The discussion includes references to specific conditions under which the body would reach thermal equilibrium, but these conditions are not universally agreed upon.
-Job-
A relatively simple question: Suppose we have a dark non-reflective body at rest in space and hit it with fair amounts of radiation. This would cause the body to heat up because it absorbs most of the radiation. After some time would the body cool down? The first guess is that it would, but why would it cool down, where does the energy from the radiation go? If we start with a body at rest, put energy into it and end up with the initial scenario then this goes against conservation of energy, right?
Science news on Phys.org
Without getting into stuff that I don't understand myself, the heat will be re-radiated as infrared (or other EM depending upon the temperature). It should eventually equalize at ambient temperature (CMB?)
So dark bodies can still be detected by analyzing their radiation emissions on different spectrums? If we have a dark, non-reflective object at rest in space, and push it so that it moves, assuming it doesn't come under any other forces or radiation, does this object now emit some radiation like its heated version (even if less)?
I'm afraid that you're getting out of my league here. I don't really know anything about black-body radiation and such. One thing I should mention is that once you heat a dark body, it isn't dark any more (using my own definition of 'dark', that is). As for simply pushing it, any mechanical push will involve some small generation of heat through conductance, compression and/or friction. Ignoring that, I think that a truly cold, dark body would only radiate gravity waves. Someone like Space Tiger really should handle this from now on. I'm plumb out of information.:redface:
I suggest that you provide a little more detail about the problem you are trying to solve.
It appears you have an object in space, you illuminate it briefly and want to know what happens to the energy. The absorbed energy heats the object. If the object was initially in thermal equilibrium with its surroundings (including the ambient radiation field) then it will eventually return to thermal equilibrium by emission of radiation. Energy is conserved.
Tide, to be more direct, why is it that, when i focus a beam of radiation on a dark, non-reflective object at rest, the object heats up instead of moving in a given direction?
Suppose i only have some amount of energy (i have no matter), how would i apply this energy to the dark non-reflective object so as to cause it to move in a given direction?
-Job-,
Actually, you would have double the momentum transfer if you had a reflective surface instead of an absorbing one. In either case, you will need an extremely intense beam to cause a "macroscopic" object to move because the momentum of the photons is very small! It can be done but the conditions have to be designed accordingly.
You may be aware of the Crooke's radiometer which has small fins suspended and encased in a glass bulb. One side of each panel is black and the other side is white. Exposing the apparatus to light does cause fins to rotate -- but the reason for it is that light absorbed by the black heats the fin AND the air in contact with the surface. It is the hot expanding air that causes motion and not the momentum transfer.
Aye, the reflectivity is important for impetus. A laser sail spacecraft , if built, will use photonic pressure from an orbital laser to impart momentum to a (huge) silvered sail. Thanks for that explanation of the radiometer, Tide. I've seen one, but didn't know that's how they work.
Actually, this is very simple. A non-reflective black body placed into space and out of sunlight, will be in a very, very cold environment.
Let's look at this:
"...if you put a physical object into space, it will reach a
temperature that depends on how efficiently it absorbs and emits
radiation and on what heating sources are nearby. For example, an
object that both absorbs and emits perfectly, put at the Earth's
distance from the Sun, will reach a temperature of about 280 K or 7 C.
If it is shielded from the Sun but exposed to interplanetary and
interstellar radiation, it reaches about 5 K. If it were far from all
stars and galaxies, it would come into equilibrium with the microwave
background at about 2.7 K."
Source: http://www.faqs.org/faqs/astronomy/faq/part4/section-14.html
So you can see that space can be a very cold environment indeed.
Anyway, when you heat up the object and then shut off the heat source, what happens? The object will attempt to go back to a temperature state equal to it's environment. Typically this is accomplished by the spontaneous emmisions of infrared photons as the object seeks to be at the same temperature as the vacuum environment.
I thought they only worked in vacuum.
No. While the pressure inside a radiometer may be low it is certainly not a vacuum!
  • · Replies 23 ·
