Theory of Everything: Water and TOE Explained
  • Context: Graduate
  • Thread starter Thread starter toe21k
    Toe Water
The discussion revolves around the concept of water in relation to the Theory of Everything (TOE). Participants explore unconventional interpretations of water's chemical composition and its implications for existing physical theories.
  • One participant suggests that water is not simply H2O, implying a deeper connection to the Theory of Everything.
  • Another participant expresses skepticism about the validity of existing physical theories, labeling them as 'questionable.'
  • A participant humorously proposes an alternative chemical formula, H1.5O, and connects it to a particle known as X(3872).
  • It is noted that the apparent missing protons in water can be attributed to quantum mechanical effects that affect visibility in scattering experiments, while maintaining that water is still H2O for chemical purposes.
  • Further contributions suggest that H2O could be viewed as an approximation involving irrational or imaginary numbers, indicating a mathematical generalization of its composition.
Participants do not reach a consensus; multiple competing views are presented regarding the nature of water and its relationship to established physical theories.
Some claims rely on unconventional interpretations of chemical and physical properties, and there are unresolved mathematical implications regarding the proposed generalizations of water's composition.
toe21k
* Water & TOE
Water is not H20...
What does that mean to Theory of Everything (TOE)?
http://www.superstringtheory.com/forum/basicboard/messages3/160.html
All the existing physical Theories such as GR, SR, QED, Standard Model, etc. are 'questionable'...
Sounds a bit preachy to me. Off to TD you go.
- Warren
H1.5O = ?
H1.5O=?
OOps...
Water H1.5O ~ Particle X(3872)...
The apparent missing protons result from a quantum mechanical effect that makes the protons less visible under certain conditions - scattering experiments. For chemical purposes, water is still H2O.
In Search of H2O = ?
H2O is an approximation of
1.?...'s H & 0.?...'s O
Isn't that [?]
  • · Replies 20 ·
25K
  • · Replies 23 ·
  • · Replies 31 ·
