Dodecahedral Metal Coordination: Are There Two Distances to Coordinating Atoms?
  • Thread starter Thread starter osskall
    Metal
The discussion centers on the coordination distances in dodecahedral metal complexes, specifically addressing the discrepancies in cation-anion distances when assuming equal anion-anion distances. Calculations indicate that with equal anion-anion distances of 2R, the resulting cation-anion distances are 3.5R for four anions and 1.8R for the other four. This raises questions about the validity of the assumption of equal anion-anion distances. Additionally, the analysis of capped trigonal prisms reveals a consistent radius ratio of 0.73, while the dodecahedron shows a minimum radius ratio of 0.83, highlighting the complexity of coordination chemistry.
  • Understanding of coordination chemistry concepts
  • Familiarity with geometric configurations of metal complexes
  • Knowledge of radius ratios in coordination compounds
  • Experience with computational chemistry tools for molecular modeling
  • Research the principles of dodecahedral coordination in metal complexes
  • Explore computational methods for calculating cation-anion distances in coordination chemistry
  • Study the implications of radius ratios in various coordination geometries
  • Investigate the behavior of capped trigonal prisms in coordination environments
Chemists, particularly those specializing in coordination chemistry, molecular modeling experts, and researchers studying metal complexes will benefit from this discussion.
osskall
Is it true that there should be two distances from a dodecahedrally coordinated cation to the two types of coordinating atoms?
When I calculate what the octahedron should look like assuming that all anion-anion distances are equal I will get two different cation-anion distances:
if all anion-anion distances equal 2R, the cation-anion distances will be 3.5R for four of the anions and only 1.8R (!) for the other four anions.
Does this make sense?
Or am I wrong in assuming that all the anion-anion distances should be equal?
What holds for capped trigonal prisms? There probably there will be a larger cation-anion distance for the capping anions, right? (Otherwise the anions would come too close! Or?)
OK, I just calculated for a triply capped trigonal prism that there is just one radius ratio: 0.73
For a dodecahedron I calculate 0.83 as the minimum radius ratio (for cation-anion interactions) but this leaves four out of eight coordinating atoms at almost twice the distance (as described above)...
10K
30K
  • · Replies 51 ·
  • · Replies 40 ·
