maverick280857
- 1,774
- 5
Hello
First of all, I am posting on PF after a LONG time so all these changes are new to me. As a result, I have, without reading prior announcements, posted this on the Advanced Physics forum instead of the other one. (To the moderator: Please shift it to the appropriate forum if you think its in the wrong place. Sorry for the inconvenience).
Okay..the problem:
Two bars of masses [itex]m_{1}[/itex] and [itex]m_{2}[/itex] connected by a light undeformed horizontal spring are lying on a uniformly rough horizontal tabletop, having a coefficient of friction [itex]\mu[/itex]. The minimum force that has to be applied horizontally to the bar of mass [itex]m_{1}[/itex] along the length of the spring in order just to shift the other bar of mass [itex]m_{2}[/itex] is
(A) [itex]F = \mu g ( m_{1} + \frac{1}{2}m_{2})[/itex]
(B) [itex]F = \mu g (m_{1} + m_{2})g[/itex]
(C) [itex]F = \mu g (\frac{m_{1} + m_{2}}{2})[/itex]
(D) [itex]F = \mu g (\frac{1}{2}m_{1} + m_{2})[/itex]
Force Analysis
Suppose the spring has spring constant k and the elongation in it just when motion of [itex]m_{2}[/itex] is to begin is x, then
[tex]F = kx + \mu m_{1}g[/tex]
[tex]kx = \mu m_{2}g[/itex]<br /> <br /> This gives part (B) as the answer.<br /> <br /> <b>Energy Analysis</b><br /> <br /> The net force on the mass [itex]m_{1}[/itex] is [itex]F - \mu m_{1} g[/itex]. The work of this force is [itex](F - \mu m_{1}g)x[/itex]. This work is stored as potential energy in the spring (since motion of [itex]m_{1}[/itex] has just started, its velocity is zero...to begin with). So,<br /> <br /> [tex]Fx = \mu m_{1}g x + \frac{1}{2}kx^{2}[/tex]<br /> <br /> Also,<br /> <br /> [tex]kx = \mu m_{2} g[/tex]<br /> <br /> solving these two equations give (D) as the answer.<br /> <br /> Which of these two methods is correct? Why is it correct? Which is wrong? Why is it wrong?<br /> <br /> I'd be grateful if someone could help me with this...the two different answers are confusing me somewhat.<br /> <br /> Thanks and cheers,<br /> Vivek[/tex]
Okay..the problem:
Force Analysis
