What is the correct way to calculate percent increase in math problems?
  • Thread starter Thread starter TSN79
    increase Percent
The discussion revolves around calculating percent increase in mathematical problems, specifically focusing on the transition of a number from 108.7 to 113.7 and the confusion surrounding the correct method to determine the percent increase.
  • Conceptual clarification, Mathematical reasoning
  • The original poster attempts to calculate the percent increase using two different methods, leading to confusion about the logic behind the calculations. Some participants clarify the correct approach and provide a formula for calculating percent increase.
The discussion has provided helpful guidance regarding the correct method for calculating percent increase, with participants exploring different interpretations of the calculations. There is an acknowledgment of the original poster's confusion and a clarification of the reasoning behind the correct approach.
The original poster's calculations included a misunderstanding of the relationship between the numbers involved, which prompted further exploration of the concept of percent increase.
TSN79
Can someone explain to me the following:
If a number increases from 108,7 to 113,7 how much in percent has it increased?
First I tried to do 108,7 / 113,7 = 0,956.
1 - 0,956 = 0,0439. In other words, an increase of 4,39%. This turns out to be wrong. 113,7 / 108,7 = 1,0459 -> an increase of 4,59% is correct, but I fail to see the logic in that the last approach is correct. What am I actually calculating in my first try?
In your first try you're finding that 108.7 is 0.956*100 = 95.6% out of 113.7.
Look at the increase from 108.7 to 113.7, it's a increase by 5 units. (113.7-108.7). Now, if we want to find how many % 5 is out of 108.7, we do (5/108.7)*100 = 4.59%. So, in general:
If a number increases from a to b, how many percent did it increase?
Answer:
[(b-a)/a]*100%
Aha, thanks a lot Karlsen!
Always nice to help a fellow citizen.
  • · Replies 17 ·
