How to Calculate the Length of Energy-Momentum Four-Vectors?
  • Context: Graduate
  • Thread starter Thread starter Jamesss
    Energy-momentum
The discussion revolves around calculating the length of the energy-momentum four-vector for a system of particles, particularly in the context of particle collisions and interactions. Participants explore different methods for determining this length and the implications of particle interactions on the calculations.
  • Jimmy asks whether to sum the corresponding vector elements of the energy-momentum four-vectors before finding the length or to find the length of each particle first and then sum them.
  • One participant suggests that the energy-momentum four-vector of the whole system is the sum of the individual four-vectors, implying that the length of the system's four-vector is derived from the sum of the individual lengths.
  • Another participant draws an analogy to calculating the magnitude of total three-momentum, indicating a similar approach should apply to the four-vectors.
  • Jimmy reiterates the question, adding that if particles are interacting, the addition of their four-vectors may not be meaningful, suggesting that only non-interacting particles or those interacting through contact forces can be added meaningfully.
  • Jimmy describes a specific scenario involving a proton collision and seeks validation for his method of calculating the lengths of the four-vectors before and after the reaction to extract the rest mass of a produced particle (Z).
  • A later reply affirms that Jimmy's method is reasonable and indicates that it leads to the largest possible mass for the Z particle under the given conditions.
Participants express differing views on the addition of four-vectors, particularly concerning interacting versus non-interacting particles. While some agree on the method of summing four-vectors, there is no consensus on the implications of particle interactions on this process.
There are assumptions regarding the conditions under which the four-vectors can be added, particularly concerning particle interactions and the frames of reference used in calculations. The discussion does not resolve these assumptions or their implications.
Jamesss
Does anyone know how you find the length of the energy-momentum four-vector for a system of particles?
p_mu=(E/c,p)
where length is:
length(p_mu)=-(E/c)^2+(p)^2
Do you first add the corresponding vector elements then find the length
OR
find the length of each particle first then sum the individual lengths.
Cheers,
Jimmy
Both values will give you invariants, although the energy-momentum four-vector ([itex]p^\mu[/itex]) of the whole system is equal to the sum of all the individual [itex]p^\mu[/itex], and therefore the length of [itex]p^\mu[/itex] for the system is the length of the sum of all the individual [itex]p^\mu[/itex].
It's exactly analogous to finding the magnitude of the total three-momentum of a system of particles. In that case, you find the total x-momentum, total y-momentum, and total z-momentum of momentum, then use them to find the magnitude of the total-momentum vector.
p_mu=(E/c,p)
where length is:
OR
Cheers,
Jimmy
If the particles are interacting through when they are separated (e.g. two charged particles) then the addition of the two 4-vectors is meaningless. Only systems of non-interacting particles anmd systems of particles which interact only through contact forces can be added in a meaningful way. To add the vectors you add components and then take find the magnitude.
This web page I created will get into great detail regarding this. See
http://www.geocities.com/physics_world/sr/invariant_mass.htm
Pete
Is this method ok?
Thanks for the clarification...
What I was trying to do was find the lengths of the four-vectors of this reaction before and after.
p + p ==> p + p + Z
Where a proton with 300GeV hits a stationary proton, then producing a particle Z.
I calculated the length of the Four-vector before the reaction in the stationary proton's frame.
I then equate this to the length of the four-vector after the collision in the
center-of-mass frame to extract the rest mass of the Z particle.
length(p_mu1+p_mu2)=length(p_mu3+p_mu4+p_muZ)
Question, is there anything wrong with my method?
I have assumed that after the collision the two protons and the Z particle are at rest, since I want the maximum possible rest mass of Z. Momentum in the COM from is zero so it should be ok?
Jimmy
Yes, that's a reasonable way to proceed. What you end up with is the largest mass the Z can have, and still be produced under these initial conditions.
  • · Replies 0 ·
  • · Replies 24 ·
  • · Replies 131 ·
13K
  • · Replies 21 ·
  • · Replies 50 ·
  • · Replies 21 ·
  • · Replies 19 ·
