How Do You Calculate the Centripetal Force of a Whirling Ball?
The problem involves calculating the centripetal force acting on a small ball being whirled in a horizontal circle while suspended from a string. The scenario includes specific measurements such as the mass of the ball, the length of the string, and the angle the string makes with the vertical.
  • The original poster attempts to find the radius of the circular motion using trigonometric methods and expresses uncertainty about calculating velocity. Some participants clarify that speed is not necessary for determining centripetal force and suggest focusing on the tension in the string instead.
The discussion is ongoing, with participants providing guidance on how to approach the problem without needing to calculate speed. There are multiple interpretations regarding the relationship between tension and centripetal force, and some clarification on the use of diagrams has been offered.
Participants note the importance of the angle of the string and the gravitational force acting on the ball. There is also mention of formatting issues with diagrams that may affect understanding.
smileyjen523
a small ball of mass 38g is suspended from a string a length 59cm, and whirled in a circle lying in the horizontal plane. The acceleration of gravity is 9.8m/s2. if the string makes an angle of 31o with the vertical, find the centripetal froce experienced by the ball.
here's the diagram:(the best i can do) it looks like a triangle when i view it but then it goes all weird in the actual view. sorry.
l\
l \
l \ 59cm
l \
l \
l O=38g
then there's the dotted lined circle drawn, but i don't know how to do that here.
ok, so first i found the radius using trig and got it to be 30.3872m. then i was going to find velocity, but then i don't know how to do that. help would be greatly appreciated. thanks sooo much.
You don't need the force to fing the centripetal force. The CF is equal to the tension of the the string along the x-axis. Since you know the angle of the string, all that you need is to find the tension of the string:
Fc = Tsin(31)
since the ball has no acceleration along the y-axis you can write:
Tcos(31) = 38*9.8 (mg)
and find the tension:)
sorry, I wanted to say that you don't need the SPEED to find the centripetal force.
Code:
l\
l \
l  \  59cm
l   \
l    \
l     \[SIZE="5"]O=38g
enclose your diagram in [ code ] tags. It helps formatting a bit, though you may still have to nudge it.
  • · Replies 22 ·
